Ok, so the water trap isn't trapping moisture from the compressed air, but simply moisture in the tank and lines. I don't see how that changes anything other than the simple statement that "compressed air has more moisture". Ok, sounds reasonable. So, in the same given square footage of air, you have compressed air, and you have ambiant air, the compressed air would have less moisture within it but the same amount of moisture would exist in both containers, right? On the video, watch it, it is very interesting how it eliminates static charge. It may very well be snake oil, but I see high end shops and manufacturing using it. Brian |
I know that compressing air makes it warm...warm air carries more moisture, the only time that the warm compressed air loses it's water is if the walls of the tank and pipe are cooler than the compressed air, (or the air cools down), ..then the moisture condenses on the walls of the tank and runs down to the bottom...Obviously all the air in the tank will never touch the walls of the tank, so some moisture goes out the lines. (rain works on much the same principal) Anyone knows on a hot day, you get moisture in your lines, because the pipes and tank are not cool enough to condense the moisture out. The moisture problem is compounded with a small compressor, working double time to keep up and heating the air even further. Some water traps and air dryers operate on a condensing principle, while others use a centrifugal force to spin the heavier water out...(just about all of those polycarbonate bowl water traps do it that way,,,watch the air swirl the moisture down the sides of the glass bowl the next time you are pondering your air lines.) Moisture in lines is a well known, well documented enemy of a good paint job..If nitrogen does not carry moisture, then that in itself is reason enough to consider it for a production shop. (I'm still unclear on that flammable thing though... J/K)Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
Sorry guys my post was confusing, brief and wrong in places, here is a paragraph that explains it better than I.
My apologies to Brian for correcting him. I hope this post is clearer. And I would like to say again that my skepticism with Nitrogen is not with painting or any other other use of compressed air versus Nitrogen use EXCEPT using it in tires. |
The point that you are missing is missing in that quote as well.
The "compressor" does not remove moisture. The act of compression by itself does not remove moisture. The tank and lines or atmosphere are where the air will "naturally" cool..(their word, not mine). If you have no tank, dryer, or intercooler or your lines are not able to cool, then the only place for the compressed air to "naturally" cool is when it exits the end of the hose into the low pressure atmosphere...and we all know that when it does that, the water falls out like rain. If the end of you hose has a spray gun on it, the water mixes with your atomized paint and f's up your paintjob. Spend any time at all working with a compressor and you will see what I'm talking about. If the compressor removed the water you'd be draining the compressor, not the tank or lines. later, mikey
Powerrodsmike wrote
Obviously when I wrote 'compressor' I was including the tank and lines as this is part of the whole set up, if this was not obvious in my post then I apologize once more for being too brief!! If we must be technically correct what myself and most people think of as a 'compressor' consists of a compressor, motor, tank and various plumbing and wiring but lets be real here have you ever seen a compressor used without a tank, and lines connecting the compressor to tank in any mechanics shop. Putting all the science and theory aside, what it comes down to is this. Everyday when I have finished using my compressor/motor /tank/lines I let the compressed air out of the tank then DRAIN THE WATER FROM THE BOTTOM OF THE TANK AND ALL TRAPS. Where does this water come from? It comes from the ambient air that has been through the compressor/tank set up. Therefore the air that comes out of the compressor is dryer than the air that went in. Now is this clear enough and can we stop arguing so I can go do some work on my car! |
Boy, I am dense, I just got what you two are talking about.
OBVIOUSLY, when the air is leaving the tank, it has left some moisture behind, the water at the bottom of the tank is the proof. The thing is, again, this is a non-science type (but I love it, so I am reading your posts with vigor ) the air leaving the compressors hose has less moisture than the ambient air in the room given the same volume. That is a fact, however, that air is jammed into a smaller area thus that smaller area has MORE moisture than the same area of ambient air in the room! So, in layman's terms and simple common sense for the non-scientist type the compressed air has more moisture. It is that "jammed together" air that is rushing out of the gun breaking the paint up and blowing it all over the object being painted. THAT "jammed together" air is full of moisture (if it hasn't been removed). Non-compressed air question, just for general knowledge: So let me ask this, hot air doesn't carry any more moisture than cold air given it was taken from the same ambient air. The hotter air just "looks" like it has more because the water molecules all bunched up together in the hotter air and we can see the moisture. Whereas the cold air has the same amount of water molecules in it, they are just dispersed throughout the air and we can't see it. Does that sound right? Brian |
I'm not missing anything about the fact that water in lines messes up paint jobs, tools and is a general nuisance. I also know how to get the water out. I know why it works, and even said so in my post. Which you quoted, then ignored.. I'm not assuming that a compressor is all of the tanks and associated plumbing.. I've seen many compressors that are consant run or on demand units that are stand alone units with very small or no tank at all. Alot of guys run those little pancake compressors which have a very small tank and if you try to use them for very long , you get water at the end of the hose. .My 7.5 hp Kaeser has a 2 gallon tank. I plumb it into a much larger remote tank where the air is allowed to cool and the water condense out.. I have very little problem with water in my lines. I had a 15 hp rotary compressor...with no internal tank at all. There are times when the tank and lines are not cooler than the compressed air, I included that scenario in the post that you quoted as well. You seem intent on saying that it is a non issue, and seem to imply that there is no real reason to use the nitrogen spraying system that is the subject of this thread. You are saying that because the air comes out of a compressor drier than when it goes in, that's good enough. (otherwise, why do you keep posting stuff about dry air and compressors?) You keep talking about how folks filling tires with nitrogen is snake oil and a scam., and how it is not necessary. If moisture in tires presents problems, then why would you not want to find a way to get rid of the problem. I know that cleaning rust off of rims so the beads will seal is a PITA. I'm done arguing. I have work to do as well. Later, mikey
Warm air will carry more moisture than cool air, that's why we have rain. Warm moist air rises up and meets cool air, where water vapor condenses and falls on us. Mikey
Ok, I am going out in the rain to the garage and work on a project. Brian |
What -- you expect me to leave it at that!!!
Brian first your question about warm air being dryer than cold air. The answer is it depends. While warm air is capable of holding more moisture, simply warming it up will cause the air to expand and keep the same amount of moisture so there is now less moisture per cubic foot than previously so we can say it has less relative humidity (drier). Only if there is water available for evaporation (lake, puddle, bucket of water, etc) can the air possibly contain more moisture than previously. So with regards to a workshop heating the air, assuming no standing water, will dry the air out (obviously). Mike I have to say you did not read my last post properly or any of my posts. You said Quote:
Most of your post says EXACTLY what I have been saying -- that in a workshop environment compressed air will give up it's moisture when it cools leaving behind water in tanks and lines, we can all agree on this. (Frankly I don't know why you keep saying I am in disagreement most of you post reinforces what I am saying and I hate arguing about details.) Personally I have never seen a compressor used without a tank, even if the compressor is not physically attached there is always some reservoir somewhere in the system otherwise like you said they would run continuously. I am not saying it does not exist simply that it is not the normal workshop set up. Here is the part I have an issue with and the part that I tried to explain in my last post. Quote:
You said Quote:
Not blowing hot air, just incoveniencing lots of electrons.!
![]() Here is something else I didn't mention. Are you sick of this yet?? I almost am but whilst waiting for some epoxy to dry I wanted to clarify a point I made to your first comment. I know I am a PITA but just bear with me on this one. Lets say your compressor is set at 100PSI and your regulator is set at 50PSI This means that the air in the line after the regulator is now capable of holding twice(edit-not sure about this now it may not be exactly twice) the moisture as the air in the tank was. (I am assuming equal temps throughout, not real world if the compressor is busy but is close if you let the air sit awhile, hope you get the point.) The ONLY way you can get moisture out of the air now, is by either compressing it back to over 100PSI or reducing the temp. of the air. This is why aircraft use Nitrogen in tires. Very cold up there (as the occasional refugee can attest to!!http://cbs5.com/local/SFO.stowaway.w...457702.htmland )not enough time to warm up the tire before landing, wouldn't do for a chunk of ice to be rolling around in the tire on touchdown. Point I am trying to make is the air coming out the line might be far from saturated and will almost always be drier than in the tank. This is what I was trying to say before to you. Edit again. ONCE AGAIN this does not mean I am saying Nitrogen in a painting system is a waste of time.(Thought I should put this in for Mike's benefit ) I am simply trying to explain my point that air that goes through a compressor/tank system that exists in a normal shop environment will go through a drying process.
[QUOTE=scrimshaw]Not blowing hot air, just incoveniencing lots of electrons.!
![]() Here is something else I didn't mention. Are you sick of this yet?? I almost am but whilst waiting for some epoxy to dry I wanted to clarify a point I made to your first comment.[QUOTE] I always thought that epoxy cured...not an evaporative process like drying tomatoes in the sun but a chemical one... Ok... you've said we agree enough for me to believe it. Brian- I used to eat the brownies and watch Mr Rogers... Later, Mikey
| Spray gun problem(long) | 62galaxiguy | Body - Exterior | 7 | 09-06-2009 03:06 PM |
| Disposable Liners for Spray Guns | starquest | Body - Exterior | 2 | 07-21-2006 08:12 PM |
| Over spray | kaw550 | Body - Exterior | 11 | 06-23-2006 07:00 PM |
| Temp. Spray Booth didn't work very well | fordSR | Body - Exterior | 10 | 10-07-2004 04:43 AM |
| I'm good with a spray can.... what am i doing wrong! | harrington | Body - Exterior | 21 | 04-25-2004 01:28 PM |
