Not only Pringles but bagged potato chips and other products such as that have been using Nitrogen for years to stay fresh and I even mentioned that earlier in this thread. Filling a bag , or can in this case, with Nitrogen displaces the Oxygen and keeps the product fresh for a long time and thats why once you open a bag and release the Nitrogen whatever is in inside will then go stale in a short time no matter how well you reseal the container. If you opened a bag of chips, for instance, and then purged the bag with Nitrogen before you resealed it the chips would then last as long as they would on the store shelves but if you simply reseal the bag without purging they would go stale i a short time.
Todays activator reducers and hardners are moisture sensitive. Why not have a small bottle of N2 and fill the container after a partial use? Would that not keep the shelf life closer to a non opened container?
How about a shot of C02? Or Argon? Or propane? or a commercially available product called Bloxygen? food for thought
I have applied clearcoat using bottled nitrogen and it worked great. Nitrogen is dry and will even further dry the surface you are painting by displacing any surrounding moisture. I used it because I had no were to paint so I went to my brothers property tied off some plastic sheathing and went at it. (SHH don't tell the EPA). Just needed to dress up the car to sell. The portability was great. You would need a full size tank like one of those 4 or 5 foot tall ones to do a whole car i'm sure. I used small bottles I would guess 20-40CF 2000 lb not even the size of a 10lb nos bottle. it took maybe three bottles but I sprayed it on pretty thick. It costs less than one dollar each where I work to fill these so cost isn't an issue.
enough Nitrogen to paint with
I work for a company that handles Nitrogen gas containers. you can obtain 6,000 psi Nitrogen cylinders and if that is not enough for you there are Large Nitrogen Dewars that generate gas from liquid nitrogen...hope this helps
I dont think nitrogen is flammable, a lot of tire shops around here use it for inflating tires ...the molecules are bigger so your tires don't loose air over time...I personaly wouldnt use it to paint with...
As far as painting with it there is a Europeon system that uses heated nitrogen. |
The gentleman in post 97 thought it was flamable ....must have been deleted right away...
I wonder what would happen if you sucked all the nitrogen out of a big bag of chips like a helium ballon? I aint gonna try it .....Lets get Mikey ....hey Mikey... |
I had a dream last night that someone here was calling my name...so my dreams really WILL come true...
Yes DBM, this is a fun thread, lots of good stuff here...One of my very favorite threads as a matter of fact...This is the one where someone said that N is flammable... I think an air dryer would do a better job of drying your compressed air, as's been said up there in the first few posts, the air we breathe is already almost 80% nitrogen... About 20' of coiled copper line aimed down with a drain at the end before it hits the main air lines works good...Works jus' like granpappy's still up in that holler. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
We had a couple auto condensers hooked up to ours that worked pretty well too..I always thought An old refrigerator with a few condencers inside would work but I never had the need here..
Dont they use nitrogen/oxygen mix for diving?I remember something about Nitrogen narcosous,where the diver gets drunk and has a good ole time, forgets to come up or gets lost in underwater caves and dies |
Turning Nitrogen into gas
The liquid nitrogen Dewars I work with have 2 valves...a liquid and a gas valve. The liquid fitting has a dip tube that uses the naturally occuring pressure that develops to force the liquid out of the fitting. The gas fitting takes the pressure that occurs right from the top. Liquid Nitrogen boils at something like 300 degrees below zero...so it is always creating pressure. I know of 3 kinds of dewars...low, medium, and high pressure. The pressure rating depends on the pressure rating of the dewar, and the rating of the safty...the higher pressure the safety the more pressure it allows to build before it opens. Never keep a dewar in a enclosed space, it will push out the oxygen
same thing they do to potato chip bags to remove the oxygen and prolong the shelf life
| Spray gun problem(long) | 62galaxiguy | Body - Exterior | 7 | 09-06-2009 03:06 PM |
| Disposable Liners for Spray Guns | starquest | Body - Exterior | 2 | 07-21-2006 08:12 PM |
| Over spray | kaw550 | Body - Exterior | 11 | 06-23-2006 07:00 PM |
| Temp. Spray Booth didn't work very well | fordSR | Body - Exterior | 10 | 10-07-2004 04:43 AM |
| I'm good with a spray can.... what am i doing wrong! | harrington | Body - Exterior | 21 | 04-25-2004 01:28 PM |
