Nitrous Bottle Valves
Are all 10 lb nitrous bottle valve fittings universal? I'm looking to pick up a used spare bottle and I am curious if the threaded connections are standard from manufacturer to manufacture.
Any assistance would be greatly appreciated. |
The bottle nut threads are the same . The valves can be different . Some are standaed , some high flow .
Also, you need to disassemble the bottle and check the siphon tube alignment and ensure that it matches your setup/alignment. You can change this. Next you want to check what kind of valve is on the bottle. Look at the burst disc/safety valve as well. Wont do you much good if you have a high flow system with a standard valve. Super Flo valves are pricey and generally you can buy a bottle with a blanket and super flo valve filled for around 350. That's a deal when you compare parting a used bottle and superflo valve. Last, if it comes with an adapter you scored! If not just transfer the adapter when changing bottles. Good Luck. |
Thanks
Yes, the bottle is out of date however, I have a friend who does hydrostatic testing for a local fire suppression company. He tested my first bottle. I'm going to play it safe and replace the valve & tube with the matching manufactures valve & gauge. Also, it did come with an adapter.
Thanks |
| All times are GMT -6. The time now is 07:18 AM. |
