Nitrous Bottle Valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2012, 07:40 PM
Are all 10 lb nitrous bottle valve fittings universal? I'm looking to pick up a used spare bottle and I am curious if the threaded connections are standard from manufacturer to manufacture.
Any assistance would be greatly appreciated.
Old 02-12-2012, 09:46 PM
Hotrod 80's Avatar
The bottle nut threads are the same . The valves can be different . Some are standaed , some high flow .
Old 02-12-2012, 10:02 PM
Last journal entry: Some More Roll Cage Fabrication
Be careful buying a used bottle. The tank might be expired and need to be recertified. Most N2O stations wont fill an expired bottle. The date is stamped near the valve. More than 5 years and you need to recert. Cost about 50-100, but it takes time. Im impatient!
Also, you need to disassemble the bottle and check the siphon tube alignment and ensure that it matches your setup/alignment. You can change this. Next you want to check what kind of valve is on the bottle. Look at the burst disc/safety valve as well. Wont do you much good if you have a high flow system with a standard valve. Super Flo valves are pricey and generally you can buy a bottle with a blanket and super flo valve filled for around 350. That's a deal when you compare parting a used bottle and superflo valve.
Last, if it comes with an adapter you scored! If not just transfer the adapter when changing bottles.
Good Luck.
Old 02-13-2012, 06:53 PM
Thanks
Yes, the bottle is out of date however, I have a friend who does hydrostatic testing for a local fire suppression company. He tested my first bottle. I'm going to play it safe and replace the valve & tube with the matching manufactures valve & gauge. Also, it did come with an adapter.
Thanks
Unable To Get Nitrous Bottle Refill k1500_3 General Rodding Tech 9 07-19-2013 03:00 PM
Nitrous Bottle Refills smokey626 General Rodding Tech 3 03-01-2009 11:03 PM
How big a bottle for MIG? rwruther Garage - Tools 11 08-14-2008 03:40 AM
2 nitrous bottles, w/ bottle heaters? 84Z Engine 6 01-29-2007 02:37 PM
All Throttle, No Bottle!!! MechaNate Introduce Yourself 1 09-05-2005 12:40 PM
