Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Nitrous cams ?
Thread: Nitrous cams ?
Old 10-13-2012, 09:00 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Many of the Crane Powermax Hyd , solid and roller cams are dual pattern and ground on wider 112-114LSA.
They make great "Nitrous-cams" You can install as per cam card or advance a bit more.
Nitrous likes less overlap (wider LSA) and a early exhaust opening point. (exhaust blow down point)
to deal with the increased exhaust gas volume.
