Nitrous cams ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2012, 07:53 PM
Nitrous cams ?
Talking small blocks here...
What is the main difference that seperates them from others... n/a cams vs nitrous cams. Valve events, lsa, ivc/evc, lift etc...
Are there any off the shelf cams that can be used ase nitrous cams by altering timing events (advance/retard)
Is there a possibility to use single pattern camshaft in a spray application ?
At what point (big shot) it should become necessary to use a nitrous camshaft instead of lets say Comp Cams Xtreme Energy camshaft or similar ground on 110 LSA ?
Old 10-12-2012, 08:57 PM
vinniekq2's Avatar
If you use anymore that 150 horse NO2,you need more than a nitrous cam...pistons,new rings,special gap,excellent ignition system..
Old 10-13-2012, 05:59 AM
And if all those things are given, forged pistons, correct ring gap, good rod bolts and a bullet proof ignition system. What kind of cams are we looking at, and can off the shelf cam be used if it's advanced some ?
Talking about 150-250 hp single shot on 350 sbc here.
Old 10-13-2012, 09:24 AM
Sorry to chime in but would this particular camshaft be ok on the spray if advanced ?
http://www.compcams.com/Company/CC/c...?csid=304&sb=2
And do i understand that if the camshaft is advanced 4 degrees. Does that alter all valve events by 4 degrees ? There for open the exhaust valve sooner ?
Old 10-13-2012, 09:40 AM
I have before used Crane Powermax 272/284 hydraulic camshaft with good result, but that was not with nitrous, only n/a. They all seem to have much split duration at 0.050" lift and adv. duration, they also seem to have more lift at exhaust valve for better scavenging right ? Then i assume nitrous likes big tube headers also.
Old 10-13-2012, 10:09 AM
Thank you sir.
How big of a shot you think it would tolerate ?
How much tighter should i run the valve lash ?
I have this thread here - Pistons and rods for sbc 350 ?
Hope you can give your self a time and read through it and tell me your oppinion as i don't want to steal this thread here. First it was about finding the right piston and rods for my strip car, but since i have that figured out i am looking for camshaft recommendation.
Old 10-15-2012, 12:59 AM
is it better to go hyd with nos or solid? or really does it matter with lifter type?
comp cams XE cams my87Z Engine 52 08-15-2012 01:09 PM
Do roller cams sound meaner than hydraulic cams? 4speed57 Engine 22 10-28-2009 01:08 PM
Anyone try Comp Cams Nostalgia Cams ? super_silent Engine 13 11-22-2007 03:01 PM
Solid cams vs Hydraulic cams, preference or power? killerformula Engine 17 02-03-2005 09:42 AM
good cams, bad cams jackflash Engine 14 08-29-2003 11:13 AM
