Nitrous fuel supply ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2007, 09:07 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Im having a problem with my fuel supply on my N20 solenoid. I have a 388 approx 450+ hp with a 100 shot plate kit on it. I have a pressure safety switch in my fuel line just before the fuel solenoid. Im running the engine with a maniacal fuel pump. Its a very big pump! Holley 130 gph with a regulator set @ 7.5 psi. I used a test light to confirm that my switch was going open under WOT with nitrous armed. System would come on for less than 2 seconds and cut off. When Im just on motor the switch will remain closed under WOT. New tank, 3/8 lines and tank unit. This is the second pump, same problem, this pump just keeps the pressure up a little longer before switch opens. Car runs 11.80s on motor. According to NOS requirements I don't even need a pump upgrade for 100 shot. And my 130 gph Holley produces more fuel output than a blue pump. But thats volume, I don't know if the pressure would be the same on a blue pump or not under WOT. I hate the noise of an elec pump. Is my switch mounted in the wrong place? Do I need to move it to before the regulator? Or is there no choice but an electric pump? NOS website has zilch on this subject. Thanks.....
Old 05-25-2007, 11:04 PM
DoubleVision's Avatar
Volume without pressure is useless.
Old 05-26-2007, 06:50 AM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
temporaly mount a fuel pressure gauge that you can see from in side the car and go try it and see what that gauge does. This will tell you if the pressure is dropping or you have a bad switch.
Old 05-26-2007, 07:17 AM
ZipZ28's Avatar
Nitrous Junkie
Last journal entry: Reflooring The Bed Pt. 2
It sounds like you have plenty of fuel pump there, the problem is probably with the fuel pressure safety switch being set at a higher pressure than what your system requires, like for an injected car application perhaps? You can test this by just putting a jumper across the 2 terminals on the switch and trying it again. If it stays activated you'll know where the gremlin is I dumped my fpss years ago after trying to get it to work reliably for several weekends, IMO a filter on the nitrous feed line is a neccissity tho',,,
Hope that helps
Old 05-26-2007, 08:49 AM
The pressure switch should have a small rubber cover in the center of it. They can and need to be fine tuned. In your nitrous instructions it should have mentioned this as well as what the preset was on the switch.
Running though for 2 seconds and then opening tells me you have a fuel pressure drop and as mentioned prior, you need to install a gauge to see what is happening. My guess is your current fuel line is too small.
Old 05-26-2007, 03:29 PM
Bowtie or Die!
Thanks for all the help guys! I will take all this into consideration and figure this out. I m going to install a fuel pressure gauge at my n2o fuel solenoid and see what the psi is under a load. If the pressure is dropping, I will install a separate fuel system for the n20.
Old 11-11-2007, 09:30 AM
same problem
I have about the same setup. I think what is happening is one of two things. The presure will drop for a few seconds when the o2 is on then go back up. The other thing is at 6000 rpm the pump will only put out 4.5 psi. What did you do? I would like to go to an electric pump but do not wont it to quit one day. I have looked at the blue pump but it might get to hot on the street. I have also looked at the 125hp but it only puts out 7psi and I have allot of money tied up in a reg and lines, so I don't want to eliminate the reg.
Helper electric fuel pump to aid my mechanical?? hotrodf1 Engine 4 06-06-2006 07:39 PM
Fuel Filter Location leejoy Engine 7 05-04-2006 08:50 AM
454, Long Rods, and Nitrous, oh my 83Silverado Engine 1 03-31-2006 09:26 AM
Designing the fuel system 66Caprice Engine 9 05-12-2005 02:57 PM
Holley carb experts? Others? Why is my truck's fuel bowl being sucked dry? MuscleTruck Engine 5 05-23-2003 12:36 AM
