Nitrous fuel supply - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2010, 02:37 PM
Nitrous fuel supply
Guys,
I"m in the process of setting up my fuel system for my 69 mustang with a 302 with nitrous. I have a 1/2" line up to a Moroso cool can then to the carb. I want to set up a second dedicated line for the nitrous and wanted to see if any thinks a stock 3/8 line with a second electric fuel pump would be sifficient to feed a 125 shot nitrous solenoid? I would think that it would be more than enough. Thoughts?
Mike
Old 09-19-2010, 04:53 PM
kficiur's Avatar
I would think, that's all I used in the past. Is it for a powershot nitrous plate?
Old 09-19-2010, 07:46 PM
ericnova72's Avatar
More for Less Racer
The 3/8" line will be enough for 250+ nitrous shot, probably 350+ when used as a dedicated nitrous feed only line.
Old 09-19-2010, 11:44 PM
Landshark928's Avatar
FrankenPorsche
3/8" line and a Holley red pump will be more than enough. Holley black pump could run the shot and the engine with a 1/2" line split before the carb.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 09:31 PM
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 08:35 PM
Idea for a future big block build RamAirZ Engine 3 09-04-2009 06:01 AM
93 Suburban fuel pump sabino56 Engine 8 09-10-2005 03:54 PM
Holley carb experts? Others? Why is my truck's fuel bowl being sucked dry? MuscleTruck Engine 5 05-23-2003 01:36 AM
