Nitrous guru's , let me pick your brain - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2010, 10:19 PM
Hill Motorsports's Avatar
Putting together a street slash strip car..
92 mustang 347 stroker, all mods..
motors 12 to 1 compression.
got a pro fogger system going to be plumbed in between the upper and lower intake manifold via plate system.. the kit is a wet system. Has a nos progressive controller , stand alone fuel system just for the nitrous.
my question is>> whats you guys opinion about cranking the juice wide open to 300horse shot with such high compression. i have done this previously with high compression but with a much smaller shot (150). now im doubling it.
the bottom end is all forged with wire ringed aluminum heads .
but i have got mixed reviews
all your answers are greatly appreciated and will go towards my final outcome.
thanks chris
Old 01-05-2010, 10:21 AM
I've run a Nitrous Works direct port fogger with a 400 HP shot and used slightly over 13-1/2 compression in one of my customers NMCA SBF engines very successfully. It was a 454 inch Windsor engine, and made 1168 HP on the dyno with nitrous. Its all in the cam. Make sure your top ring is down on the piston and a stainless top ring is a good idea.
Old 01-05-2010, 10:50 AM
Last journal entry: PICTURE TEST
dope
The engine needs to be built with the 300hp shot in mind. proper ring package, ring type and gaps etc.
IMO the biggest problem is the tuning. Most guys will try to force a tune on the engine, like xx amount of timing or this heat range plug because it's what there buddy ran.
You need to stat out with the small jets and a over safe tune. Pay attention to what the engine is telling you and work your way up. If you look at whats going on you will have zero problems with that hit.
If you miss it BOOM!!!!
Keith
Old 01-05-2010, 11:48 AM
Keith your absolutely right. Don't try to start at the top, work your way up slowly.
pick up coil jmbjs Electrical 1 04-29-2006 04:42 PM
Thinking about building a purpose built nitrous motor! Please critique leemoses Engine 22 06-19-2005 09:15 PM
Nitrous Problem, Maybe fuel pump? esears Engine 7 05-02-2005 05:21 AM
State of Arkansas outlaws nitrous on street-driven vehicles hoodoo Hotrodders' Lounge 23 04-20-2005 01:03 AM
Help me pick a new camshaft!!! MEAN_SBC Engine 28 08-02-2004 09:09 PM
