nitrous oxide - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2005, 03:41 AM
nitrous oxide
I just bought a partial nitrous oxide system does anyone have a list of all the parts without purge that I'll need for a 100 hp -150 hp 4 barrel application???
Old 02-21-2005, 06:40 AM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
What'cha got now?
Old 02-21-2005, 10:38 AM
Matts99Sierra's Avatar
go look at the kit that summit or jegs has and see what you dont have and see what you need
Old 02-21-2005, 11:33 AM
What do you have now, Off the top my head you will need spray bar nitrous/fuel lines (to the spray bar), fuel and nitrous selonoids, Nitrous/fuel lines (to selonoids), bottle all the wiring like a relay fuse WOT switch and an arming switch. You will also need at least 6 psi of fuel when the system is activated and fuel pressure safety switch (not needed but good safety device)and the proper jets.
Old 02-21-2005, 06:14 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Call Summit or Jegs up, they will gladly tell you/sell you all the remaining parts you need.
Old 02-21-2005, 06:46 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
As Ghetto Jet said, call most any speed-parts tech-line or a nitrous system manufacturer's tech line.
Nitrous Oxide How much is to much ManfromKy Engine 9 04-05-2004 09:09 PM
Nitrous Oxide Questions nightrain_rod Engine 23 06-25-2003 11:59 PM
Nitrous Oxide PontiacTA79 Engine 2 05-28-2003 02:24 PM
what do u think about nitrous oxide???????? neil madsen Hotrodders' Lounge 5 10-23-2002 07:17 AM
85 camaro with 383 stroker with nitrous oxide or twin turbo? camaro dan Engine 0 10-08-2002 06:18 PM
