nitrous problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2007, 04:15 PM
nitrous problem
I have a 100 shot nitrous at about 5,600-5,800 it seams to go down in power I think I am just out of the power band. It does not ping or anything. The cam is 2,600-6,100 so I think this might be normal. What do you think?
Old 09-10-2007, 04:30 PM
Is this going thru a gear change or holding in the same gear?
Bogie
Old 09-10-2007, 04:33 PM
It is topend
it is the topend. I have a 4.11 with 26" in a th350.
Old 09-10-2007, 06:11 PM
DoubleVision's Avatar
Nitrous, low gears and small tire height makes for quick revibility so the amount of time in gear isn`t long before it runs out of cam. So I`d say yes you`ve figured it out on your own, if your in high gear close to the finish line and if you have a memorey tach or can sneak a look at the tach to see where the rpm is it should tell you all you need to know. If it`s running out of cam no amount of nitrous will keep the powerband going. We learned this same thing in our early years of dragging.
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 08:07 PM
Timming and nitrous question Ratoflic Engine 0 07-07-2007 03:55 PM
I'm having a primer adhesion problem on one door Ripped Body - Exterior 10 06-08-2007 12:45 PM
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 03:44 PM
Nitrous Problem, Maybe fuel pump? esears Engine 7 05-02-2005 05:21 AM
