Nitrous Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2010, 11:09 AM
prettyboyced's Avatar
Nitrous Problems
i have a 125 NOS wet shot on a chevy 350 tbi heads 270 cam edelbrock carb 600cfm 32 degress total but my problem is when i push the button is that i dont feel much of a difference at all so i was wondering could it be my timing off or am i running lean
Old 07-11-2010, 02:28 PM
F-BIRD'88's Avatar
Yada Yada Yada
inline Nitrous filter plugged. Clean it. Excessive nitrous bottle pressure. The nitrous solenoid will not open if the bottle pressure exceeds 1000-1100 PSI.
Nitrous pressure 850psi bottle temp 85°F max. (Cool the bottle if nesessary)
Nitrous fuel pressure 5.5 to 6psi steady flowing.
Spark plug gap max .035" Use high octane gas.
Old spark plugs/carboned up combustion chambers (city driving) will imediately foul.
Is the bottle empty or over filled?. weigh the bottle.
Old 07-12-2010, 08:39 AM
DoubleVision's Avatar
Stock tbi heads? big mistake. These heads shut off at 4000 RPM due to the swirl vane in the valve bowl. nitrous or not, if it can`t get in the cylinder it doesn`t do any good.
Old 07-12-2010, 12:47 PM
not really i have power all the way to 5500
Old 07-12-2010, 07:21 PM
It will rev to 5500, just as my 4.3 V6 with TBI and swirl heads will, but the power stops at 4000. Flow is power, and swirl port heads are the worst flowing heads in SBC history.
Idea for a future big block build RamAirZ Engine 5 09-04-2009 05:01 AM
Nitrous and Bracket Racing why is it not consistant? Quarter Flash Engine 5 06-16-2008 10:17 PM
Nitrous on my 01 vet? Quarter Flash General Rodding Tech 3 08-31-2006 07:57 AM
nitrous on my 350 sbc? Trav Engine 16 10-25-2003 10:32 AM
HOMEMADE NITROUS SYSTEM fordracing Engine 12 04-12-2003 03:48 AM
