Nitrous Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2003, 10:21 AM
jamnut's Avatar
Rebuilding AGAIN!!!!
Nitrous Question
We are putting a plate system on one of my cars. The intake doesn't have a vacuum port that I can hook my PCV up to, so I took an aluminum spacer & drilled it out and put a Fitting on it for the pcv to get Vacuum off of. The carb is a Speed Demon 750 & I'm using the vacuum port on it for the Power Brakes. Now when I put this plate system on the car where should I get my vacuum source from. Would it be a bad idea to drill & tap the Nitrous plate & put a fitting in it like I already have on the carb spacer, or should I put the carb spacer on top of the nitrous plate?
Someone please give me some good ( feasable ) ideas.
EDIT: Drilling and Tapping one of my intake runners isn't an option that I want to use.
Old 08-29-2003, 11:53 AM
drjimmy's Avatar
New Member
I put a T in the power brake vacuum line and got it there.
Old 08-29-2003, 12:07 PM
jamnut's Avatar
I had already thought about putting a T in the line, but due to the size of my cam I'm already almost power brake challenged even with a Vacuum canister hooked up to my power brakes. And I also don't want to do away with my PCV and switch to a valve cover breather setup either.
Old 08-29-2003, 02:55 PM
Summitracing.com sells a electic vacuum canister for power brakes for running a large cam. You could use it for your power brakes and free up the vacuum port on the carb for your PCV. This would also give you adequate vacuum for your brakes.
1984 Pontiac Grand Prix
-350 4-bolt main
-Torker II Intake
-Holley 600 cfm 4-barrel
-Flowmaster Afterburner headers
-Turbo 350 Transmission
