Nitrous Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2013, 08:06 PM
Nitrous Question
He guys, I have a carb setup on a 98 camaro and barley have room to close the hood. I am wanting to install nitrous and am wondering if I could install a couple of foger nozzles in the carb hat. Would it be ok to spray nitrous and fuel above the carb?
Old 03-18-2013, 09:42 PM
33Willys77's Avatar
Thats a lot of pressure coming out. The plates are angled to shoot towards the runners and nozzles are shaped to spray down into the runners. I would think you would not have good control just spraying on top and could lead to tunning issues and could spray gas outward which would also be a hazard. Put the nozzles in the intake if you dont have room for a plate (1/2").
Old 03-20-2013, 10:54 AM
The TopShot system installs above the carb, on the aircleaner stud...
Old 03-20-2013, 10:58 AM
I appreciate the reply, but I have to run a carb hat with a filter similar to a late model efi setup. I am very constrained for space.
Old 03-20-2013, 11:09 AM
spinn's Avatar
I have used dry kits in front of the throttle plates and it worked with a micro switch . If you have not been told adding fuel in front of the throttle plates is not the best strategy. Could be dangerous.
Old 03-20-2013, 12:35 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Yep it could:
Opps...........LOL
How would you purge a set up like that??.
Nitrous/ET question chevyguy13 Engine 12 09-23-2010 11:38 PM
Nitrous question ...jasper... Engine 1 08-10-2008 08:56 AM
Nitrous Question xxllmm4 Engine 1 05-13-2007 03:41 AM
nitrous question syclone Engine 16 09-15-2005 07:22 PM
nitrous question traub83 Engine 3 05-22-2004 12:07 AM
