nitrous in stages - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2012, 03:18 PM
FKR FKR is offline
nitrous in stages
How much nitrous in stages is consistant, safe and reliable?
Old 05-22-2012, 03:33 PM
That depends on your motor's capacity for additional power, and your method of applying the NOS, and your cars ability to put the power to the track.
If your motor isnt overbuilt to accept what you throw at it, poof. I see plenty of peoples cars set up to 300+300, and am sure that the Pro type classes use much more than that.
Old 05-22-2012, 08:37 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
There are some local grudge racers in my area that I talked to one day. They have a plate and two foggers on a small block ford... runs high 7s in the 1/4 in a fox body. I believe they told me by the end of the track they are spraying around 800-1000hp. So... if your engine is built for it you can do it but It totally depends on what you have and what your working with. Too many variables to say xx amount is safe.
Sanding between stages Coaner Body - Exterior 8 06-15-2011 06:53 PM
Horror stories - painting in stages hgufrin Body - Exterior 22 07-26-2006 02:13 PM
Painting in several stages Render Body - Exterior 5 06-22-2006 04:12 PM
Epoxy primer in stages pigman Body - Exterior 4 06-21-2005 02:30 PM
In the planning stages Gandalf Hotrodding Basics 8 02-10-2005 06:37 PM
