Hotrodders Bulletin Board > Tech Help> Transmission - Rearend
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 07-28-2005, 01:19 AM
347mustang's Avatar
347mustang 347mustang is offline
nitrous with a stick
i am going to run some nitrous on my mustang..it has a 5 speed..i have used nitrous before but with a automatic...what would the best way to go about turnign it on and off..in between gears
  #2
Old 07-28-2005, 05:45 AM
ZipZ28's Avatar
ZipZ28 ZipZ28 is offline
Nitrous Junkie
Last journal entry: Reflooring The Bed Pt. 2
My car is a M6 and I use a MSD Window switch like This I have mine pilled at 3200 on and 6600 off with my rev limiter set at 6700. Just set it so it cuts the spray off before the rev limiter kicks in and you should be good to go.
Old 07-28-2005, 10:25 AM
347mustang's Avatar
not to sure if that will work on mine...my motor hits the rpm;s so fast...it makes your head turn..maybe i will just have tompractice and use a regular button
Old 07-28-2005, 10:36 AM
1931 steve's Avatar
1931 steve 1931 steve is offline
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
I just went for a ride in a Ford Ranger with a 351 with a stick that runs nitrous. He is running a MSD Window switch and a MSD Retard box to control the nitrous. He also runs a MSD 6AL box with the rev limiter. If you engine revs that quickly I STRONGLY SUGGEST some sort of override for the nitrous.Window switches work very nice. One mistake and it could be over for your engine.
Steve
Old 07-28-2005, 11:13 AM
ZipZ28's Avatar
Nitrous Junkie
IMO a button is a bad idea, especially with a shot of any size, say 100 or more. The better you control the nitrous coming on the less chance of pushing a rod through the block at low rpm from the added torque. The motor needs to be spooled up some (IMO at least 3K rpm) to avoid that. Just my .02 worth,,
Old 07-28-2005, 07:10 PM
broncoII88's Avatar
broncoII88 broncoII88 is offline
Do the right thing...
I didn't think that a 351 would fit in a ranger! Maybe I can slip one in my Bronco II!!!!!11
Old 07-28-2005, 09:45 PM
347mustang's Avatar
fyi..there is a man at the track here that has a 460 in a ranger
Old 07-28-2005, 10:22 PM
1931 steve's Avatar
Wiki Edits: 4
This engine fit in the Ranger like it was made for it. I have an S-10 with a SBC in it, and the Ranger 351 fits sooooooooo much better. The next time my buddy Scott drives it up to the shop I will take a few pic for you. The Ranger is a 1988.
Steve
Old 07-30-2005, 09:45 AM
broncoII88's Avatar
Hey thanks! My bronco II is an 88' too! I'm thinking that the heater box is probably gone to make room for the valve covers, Header/frame clearance is an issue, slave cylinder/header clearance, new trans, t case, driveshafts, axels to handle the new power...........This sounds a lil to expensive for me! Maybe if I won the lottery..
Old 07-30-2005, 09:11 PM
chrisflock's Avatar
chrisflock chrisflock is offline
Last journal entry: A quick trip
I've heard of people hooking a nitrous safety switch up to their clutch pedal, just like a cruise control cut off...so when you push in the clutch, the nitrous cuts off, and will kick back on when the pedal hits the stop.
In fact, the guy I heard about used a brake light switch to do it, and he even used the mounting point for the cruise switch (his car had no cruise) to mount it up...he said works great. I believe that he said something about an RPM setup on it too, where he could dial in what RPM it would kick in at, but that's really all I know about it because at the time I had no real interest in putting a NOS setup on my car (nor the money...)
Chris
Old 08-01-2005, 04:16 PM
bigbadbowtie's Avatar
bigbadbowtie bigbadbowtie is offline
Bottle Fed
My suggestion is to run a WOT switch in series with a window switch.
If somthing ever breaks in the drivetrain and your at WOT on the gas its going to rev to the moon before you can get off of it. Been there done that...its not fun to run over the crank or have a custom windowed block. :-)
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "nitrous with a stick"
ThreadThread StarterForumRepliesLast Post
Thinking about building a purpose built nitrous motor! Please critiqueleemosesEngine2206-19-2005 10:15 PM
State of Arkansas outlaws nitrous on street-driven vehicleshoodooHotrodders' Lounge2304-20-2005 02:03 AM
Nitrous MythsMatts99SierraEngine702-13-2005 09:27 AM
408 bbc nitrous68chevelle_ssEngine504-05-2004 01:57 PM
nitrous with high or low compression?brainsboyEngine503-19-2004 06:23 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
