Nitrous + stock pistons = bad. Pics included! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2008, 09:29 AM
Heres an example of why its not a good idea to use nitrous on stock pistons.
The piston in question are out of a '94 Z28 with a 150 horse shot of N2O.
Not only does it cause piston wall scuffing as seen in pictures one and two, but it also usually causes SEVERE piston shrinkage.
Beware!
ID:	30085   Click image for larger version
ID:	30086   Click image for larger version
Old 05-20-2008, 02:38 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
can't really see much from the pictures.... other than the pistons in that motor are SMALL!!
Old 05-20-2008, 03:51 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
With a piston that small, the Z must be a V12.
Either that or someone has a HUGE hand.
Old 05-20-2008, 04:33 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Har-dee-har-har
Old 05-20-2008, 05:23 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Nice way to say "your vise is bigger than mine"
R
"SlowRide66"
"Illegitimis non carborundum"
Old 05-20-2008, 05:32 PM
T-bucket23's Avatar
Wiki Edits: 26
Looks like a lawn mower piston
Old 05-20-2008, 05:50 PM
That can't be a very good spot for all them what looks to be fireworks right across from a bench grinder like that ehhh...
Old 05-20-2008, 11:18 PM
The grinder is temporarily off limits.
Alright you caught me, its a 31cc weed whacker piston.
On a more serious note, I will now avoid buying Poulan brand products (available at any fine wal-mart retailer). The piston had at the very most 10 hours of run time and has some serious scuffs on the walls. Yes, I remembered to mix in the oil.
Old 05-20-2008, 11:53 PM
Docc's Avatar
Dry Heat
Last journal entry: along the weird tale..
Dam..I never thought of runnin' a bottle on my weedwacker....!
Old 05-21-2008, 06:24 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Talk about small pistons.
This is a Honda Civic I'm currrently rebuilding.
I can't get my hand into the cylinders to wipe them down
Old 05-21-2008, 07:41 AM
[QUOTE=jcclark]Talk about small pistons.
aww thats cute kinda resembles an engine only smaller
Old 05-21-2008, 07:51 AM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
[QUOTE=HalfOunce]
That started my day off with a laugh.
Old 05-21-2008, 09:24 AM
jcclark's Avatar
The Penny Pincher
High perfommance on a small scale.
96 cu. in., 127 HP, but best of all,
over 30 mpg...........IN TOWN (LOL)
Sorry, I didn't mean to hijack this thread, but you
gotta see the cam on one of these V-Tech engines.
They use a different lift lobe at higher revs-lots of lobes.
Old 05-21-2008, 09:55 AM
CrashFarmer2's Avatar
Freezing in arctic Iowa
Last wiki edit: Pre-1980 VIN decoding
Last journal entry: 1978 Chevy pickup battery tray repair
Wiki Edits: 409
I would have returned it.
I bought a 2-cycle tiller at Farm and Home in Creston. The thing didn't run ten minutes before it seized up. I called Farm and Home, they told me I had to take it to NAPA in Creston. It turned out to be some defect in the engine caused it to seize and I got another tiller.
I have been using Poulan chainsaws for a number of years now. I heat with wood so I they get a lot of use. When the chainsaw blows up I just go buy another one. With the savings on heating my home I can easily justify buying at least one chainsaw a year. One lasted a little over a year when it quit oiling the chain, it still runs fine and I was going to tear it apart and see what is wrong with it but they are so cheap why bother, just go buy another saw. The last one lasted a little over three years before it blew up. I have considered buying a more expensive brand but then I would be tempted to fix it when it malfunctioned.
Old 05-21-2008, 01:23 PM
Rob Keller's Avatar
Wiki Edits: 38
I bought a Poulan Wild thing saw .
its named right pull & Pull & Pull & Cusss
Pull & pull & pull & Cuss!!! the start cord would wrap up inside!
Pull & pull & pull & Cuss!!! the choke lever falls off!!!!
Pull & pull & pull & Cuss !!!screw it I threw it @ the stump of the last tree I ever cut & busted the fuel tank !
I 'll never buy another saw unless its a Stihl or Huskavarna
NEVER NEVER EVER NEVER
RRRRRRR
R
"SlowRide66"
Stock eliminator 78 monte Engine 5 01-02-2003 06:10 AM
Can you use oversized rings in stock pistons stonedchihuahua Engine 4 12-06-2002 07:30 PM
What are the odds these pistons are stock and not rebuild ones? stonedchihuahua Engine 6 12-01-2002 01:49 PM
Forged Rods and Pistons for Ford 302? Mustang 69 Chile Engine 6 10-21-2002 07:39 PM
2.02 valves on stock 302 pistons mustang66maniac Engine 3 08-06-2002 12:30 PM
