Nitrous tap & drill size - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2010, 02:07 AM
454headache's Avatar
What size drill bit should I use to drill the holes for a standard nitrous tap (1/16 -27 NPT)?
Old 07-22-2010, 04:41 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
That requires a letter size "C" drill bit or 0.242
Old 07-22-2010, 06:12 AM
Frisco's Avatar
Glad To Be Here
Go HERE to see a complete tap & drill chart.
For 1/16-27 NPT it shows the drill size to be a 'D' (.246) drillbit.
For 1/8-27 NPT it show the drill size to be a 'R' (.339) drillbit.
I mention both sizes here because a 1/16-27 NPT is not a common size and more than likely the 1/8-27 NPT is the size you will be using.
Old 07-22-2010, 06:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
HERE they recommend a 17/64" drill size.
HERE Holley recommends a 1/4" drill bit. And again in the NOS installation instructions HERE.
HERE, they say:
Tap size- 1/16"
Threads per inch- 27
Drill size w/ taper pipe reamer- 15/64"
Drill size w/out taper pipe reamer- "D"
Straight pipe threads- 1/4"
Last but not least, HERE they recommend a "C" (0.2420") bit.
So, choices are (in inches, except C):
0.2656 (17/64)
0.250 (1/4)
0.2420 (C)
0.2343 (15/64)
If I were drilling/tapping aluminum I would use a smaller bit and back the tap out often to clean it. Steel I would tend to use a slightly larger bit.
Basic Nitrous question renfroe453 Engine 6 10-13-2009 07:52 PM
Drilling Hole In The End Of A Trottle Shaft 345 desoto Engine 3 09-06-2008 10:30 AM
Nitrous question ...jasper... Engine 1 08-10-2008 08:56 AM
Drill and tap follow up Walker Engine 2 07-20-2003 10:24 PM
tap tap tap elcaminoescondito Engine 3 11-25-2002 06:45 PM
