Nitrous throttle switch position - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2009, 12:52 PM
9K-sbc's Avatar
Has anyone experimented with having the shot come in at any other time besides at the very end of WOT?(throttle switch) say 2/3 throttle etc. I've always ran mine at the very end and all of the instructions you read say "very end". Just wondering what happens when you have it come in earlier. Of course, I'm too paranoid to try it myself. Also what happens if you set it to come in at 3,000rpm(rpm activated switch) and you're not at WOT?
Haven't been running nitrous that long, so I need advise from experienced users.
Thanks
Old 10-24-2009, 01:09 PM
DoubleVision's Avatar
At less than WOT it causes high loading which can cause parts breakage. Many racers hit the nitrous when the car comes off the line, but there at WOT. I`m sure there`s other varibles i`m not familiar with that also cause breakage.
Operation of Vacuum Switch for TCC Lockup JohnTN Transmission - Rearend 1 07-11-2009 12:23 AM
ignition switch wiring fivewindowcoupe Electrical 3 01-29-2009 04:50 PM
Ignition switch config coupe66 Electrical 9 01-07-2008 07:47 PM
Calling the DOC..66 Impala headlight switch issue black66 Electrical 7 06-01-2006 04:46 PM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 09:31 PM
