No 4th gear on a 4L60E Transmission.
Dear Tranny People.
My 1997 blazer only 70.000 mls won´t shift in fourth anymore. How is the process to start with the root cause analyse? I apresciate your help and thanks in advance. Monette999 |
Welcome to Hotrodders.....This is the Introduction forum, so it would be best if you posted your tranny question over in the Transmission forum.
moving it..........
Ontario Rodders |
With the CEL on... what codes were set?
Does reverse gear still function? there are 2 shift solenoids. IF you have a good solid first gear(both solenoids "on") I doubt the problem is a solenoid. Have the vehicle scanned with a quality scanner. You need to see the data stream of the ECM to the trans. Check for command for shift to 4th gear. Has this trans been serviced recently or ever in 70k miles of the vehicles life?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Hello Crosley,
There was no error code listed. The engine check light is present. I forgot that failure code. yes the reverse gear still works fine and all other gears as well except the 4th. and I have a good first gear. What is a quality scanner? Is it like the Tech 2 from GM for onboard diagnostics. The transmission oil was checked by shop. They said it is ok. But i doubt that a service was made before by the previous owner. Do you mean an actuator element test with the service tool. Is there only a ECM engine controle module or as well a TCM. If I have a wire break or bad connection or mechanical failure and the command shift to fourth gear won't tell me anything. How can I check for this failure.Can I get a feedback signal of the shift command at the transmission connector. Regards monette999 |
If the check engine light is on... there is a code set. You forgot the code? Bummer, try to scan the system again or clear the codes , then drive the vehicle for several miles.
Most of the cheap "code readers" can not scan deep enough into the vehicle system to read needed info. There are several quality scanners. I use Snap on Modis. With all the tech stuff you are quoting & searching for , you must be reading all this stuff off the internet or something. As I posted a quality scanner hooked into the data stream to check for inputs to the trans and back. Some wire problems do show up on a scanner hooked into the system. Some scanners read out the voltage , resistance of the solenoids & PCS systems Also , as I posted the shift solenoids are both applied in first gear and appear to function. I doubt this is an electronics problem in your trans , possibly a mechanical failure as I list below. You may have a worn out 2-4 band. A check of the servo cover travel with a pry bar would indicate that to a knowledgeable trans person. The servo is a multi-stage unit... 2nd gear can function fine , yet 4th gear will not hold power since a different section of the servo applies the band in 4th gear. there could be a broken , cracked accumulator piston for 4th gear... a worn, scored up bore of the 3-4 accumulator. good luck , post back with info when you can.
Here the failure code
07531-2 Shift Solenoid Cuircut Electical This is the failure code. What does it mean? I have a 1,2,3 gear, can shift them all. As well a reverse. Hope you can give some good advice Monette99 |
No 4th 4Gear on 4L60E Blazer trans. P0753
Hello Hotrodders,
I have a P0753 failure code stored in my ECU and thy symton in no fouth gear. The failure code descition is: 1-2 Shift Solenoid Circuit Electrical. I am confused a bad solenoid and oly loosing the forth gear. Thanks for help. Monette999 |
Swap in a pair of new shift solenoids (2) , see if that fixes the trans.
I'd add a new filter and pan gasket too.
GM 4L60 transmission reverse stucks when put it.
Dear Tranny Poeple,
recently my 97 Blazer is not going in reverse. I feel some resistance but the grear in not going in. It put it back on park and then repeat. Than it is working. How do you swith on reverse on the solenoids? I apresciate any help. Thanks Monette999 |
| 700R4 will not shift into 3rd and 4th gear | bebopwally | Transmission - Rearend | 14 | 05-25-2006 07:48 PM |
| 4L60E Stays in first gear!!!!! | Cletis234 | Transmission - Rearend | 10 | 05-22-2005 08:19 PM |
| 4L60E transmission problems | BICHN69 | Transmission - Rearend | 6 | 03-26-2005 11:32 AM |
| 4L60E transmission problems | BICHN69 | Engine | 1 | 08-14-2004 11:23 PM |
| 1st, 2nd, 3rd! No 4th gear | Deadtemple | Transmission - Rearend | 6 | 10-15-2003 08:15 PM |
