No Air coming out of defrost only front vents - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-08-2010, 04:34 PM
crap how come the pics didnt work?
  #17 (permalink)
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
Ummm, I cant see the pics but a friend said if it has a reservoir, it should be located under the battery tray...hope this helps
  #18 (permalink)
Old 08-08-2010, 04:52 PM
Ok lets try this again!
First one is the switch with the lines attached
2nd is of the lines and connector
3rd is of the vacum valve thats connected to a trap door on top on the passenger side
4th is another vacum valve in the center behind dash..*NOTE* there is another one right above it*NOTE*
5th one is a line thats just sitting there it wasnt connected to anything and theres nowere to connect it anywhere back there..... an atmospheric vent maybe?
ID:	47249   Click image for larger version
ID:	47250   Click image for larger version
ID:	47251   Click image for larger version
ID:	47252   Click image for larger version
  #19 (permalink)
Old 08-08-2010, 05:56 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I would check for vacuum at the one that's not connected,
  #20 (permalink)
Old 08-08-2010, 07:46 PM
CDJr's Avatar
Experienced Amateur
Wiki Edits: 2
All 6 vacuum lines are plugged into the rubber boot behind the switch...5 of them go to the various positioning diaphragms and the 6th is the one that supplies the vacuum, which is the one you need to trace.
  #21 (permalink)
Old 08-08-2010, 08:00 PM
alright perfect now im getting somewhere! thnx alot guys ill keep ya all posted
  #22 (permalink)
Old 08-08-2010, 09:11 PM
Hey guys does this set up look familiar? that vacum line runs up into that big hose and then from there i dunno im done for the night those bloody mosqitos are horrible up here!!
  #23 (permalink)
Old 08-09-2010, 07:20 AM
T-bucket23's Avatar
Wiki Edits: 26
It is not unusual for those hard vacuum lines to break inside one of thos harnesses.
You need to get back to basics, determine if there is vacuum in the car, if not trace the line back and find where it is broken.
You are making this into something bigger than it is.
I am betting you have one of those hard plastic vacuum lines broken under the hood. They get very brittle from the engine bay heat after a few years
Chet
  #24 (permalink)
Old 08-30-2010, 08:28 PM
New Member
I went thru a similar problem with my 97 except it was the defroster that acted up.Here is a picture of the 3 vacuum actuators (for a 97) under the dash above the gas pedal.Check to be sure they are all connected properly and push/pull the respective arms that control the dampers in your heater box. You'll probably find one that's dangling down when it broke off. The plastics arms get old and fracture easily.
__________________________________________________ _________________
Last edited by 68NovaSS; 01-16-2012 at 01:43 PM. Reason: Advertising. Please see: commercial posting guidelines.
Rant about aftermarket sheetmetal cyclopsblown34 Body - Exterior 27 01-28-2010 10:14 AM
Air duct bezels coming along americanLT1 Body - Exterior 3 08-25-2009 11:37 AM
air on a solid front axle? 427v8 Suspension - Brakes - Steering 20 11-14-2007 10:24 PM
air filter location. yus Engine 1 08-04-2006 08:28 PM
Front Adjustable air shocks in an Impala? ataririder Suspension - Brakes - Steering 3 02-09-2003 09:59 AM
