Okay , you said you checked the vacuum lines from the control to the servos , right ? I didn't see where you confirmed vacuum coming to the control . There should be a plastic vacuum reservoir somewhere (probably under the hood) . Let me know what you find. Confirm vacuum to the switch/control first and if not , trace back towards the engine from there .
Most vehicles default to defrost when there is no vacuum to move the servos, but that one could be an oddball, the previous advice is a good start,
Thanks for the reply,
No i am not getting vacum at the switch itself. when i put my hand over the connector that plugs into the switch there is nothing. I will take a look for that plastic reservoir later on tonite and see if i can find it. What am I looking for as far as malfunctions go? with that reservoir? Ive never done this kinda job before so im goin in blind but like i said i replaced what i could so far and got stuck haha. |
Just get vacuum to that reservoir, and from there to the vacuum switch and you'll probably be good to go,
On my 94 Formula the hose goes straight from the controls to a tee in the vacuum line with check valves in it. Its located on the passenger side just in front of the firewall. But it has no reservoir that I know of.
Im with Rick, Im curious as to why its not defaulting to the defrost vents.... |
The vacuum switch part of the controls is probably NG. You need to get a vacuum diagram.
Is the defrost mode the only one that doest work. Does it blow at teh floor when you put it on heat.
Artificial Intelligence is no match for Natural Stupidity Chet |
thats the thing tho, i replaced that switch cluster along with the vacum valves so that should be all good.... and no it is not blowing underneath just out of front vents hot/cold it is getting absolute zero vacum...... and now that i think of it i dont know if this would help any but when i put my hand over the defrost vent it almost feels like its SUCKING my hand down instead of blowing out???
In that case, Id trace the black vacuum feed hose that goes to the switch through the firewall into the engine bay and find out where its cracked or disconnected. Im still curious as to why itd default to the panel vents instead of the defrost vents though...
To make sure thats the problem you could simply pull a vacuum on the back of the switch and then see if the switch will make it blow outta the top or bottom vents. |
If you think the defrost vents might be sucking just light a match and blow it out then hold it near the vents, the smoke will tell you what's going on. Or you could use a ciggy if your foolish enough to smoke
[IMG]p8089849[/IMG]
Ok this is the switch with the vacum lines connected to it [IMG]p8089850[/IMG] This is the vacum lines/ connector [IMG]p8089852[/IMG] This is the vacum valve on the passenger side which is connected to the trap door i beileve is for the defrost [IMG]p8089853[/IMG] This is another vacum valve in the center of dash and then there is another one right above it forgot to get pic of it [IMG]p8089854[/IMG] This is a line i have no idea for its just there it wasnt connected to anything... could be just a atmospheric vent of some sort??? [IMG]p8089855[/IMG] This is where everythings connected underr hood i couldntt find no reservoir |
| Recent General Rodding Tech posts with photos |
| Rant about aftermarket sheetmetal | cyclopsblown34 | Body - Exterior | 27 | 01-28-2010 10:14 AM |
| Air duct bezels coming along | americanLT1 | Body - Exterior | 3 | 08-25-2009 11:37 AM |
| air on a solid front axle? | 427v8 | Suspension - Brakes - Steering | 20 | 11-14-2007 10:24 PM |
| air filter location. | yus | Engine | 1 | 08-04-2006 08:28 PM |
| Front Adjustable air shocks in an Impala? | ataririder | Suspension - Brakes - Steering | 3 | 02-09-2003 09:59 AM |
