no brake lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2011, 02:29 PM
no brake lights
I Have Tail Lights But No Brake Lights On My 1923 T-bucket.
I Even Switched From A Pressure Brake Switch To A
Manual Switch And Still Nothing Sent Diagram Into People
At H.a.m.b. And They Said I Have It Wired Correctly.
I Even Checked To Make Sure Double Filament Bulb And Grounds
Are Good.
Please Help
Old 09-01-2011, 03:07 PM
EOD Guy's Avatar
Silly question is the socket you are using, a double wire or single wire?
If it's a double..... hook a jumper from a 12v source to the brake light pole/wire/side of the light socket - it should light, trace the brake light wire back towards the brake light switch, to the next connection , jump that - it should light etc..... until you get to the brake light switch etc..... If it lights at both sides the switch with a jumper..... are you getting 12v before the switch?
Old 09-01-2011, 07:43 PM
Cape Cod Bob's Avatar
go here and this may help u.
http://www.oldengine.org/unfaq/signal.htm
Brake lights Aizawl Electrical 2 03-26-2011 03:16 PM
brake lights fast79malibu Electrical 4 01-28-2007 07:04 PM
voltage to tail lights vs brake lights? stratt134 Electrical 12 06-10-2006 06:51 PM
Brake lights, head lights 40chevy Electrical 9 05-03-2006 08:59 AM
LED tail lights, third brake lights ? 1 Day Electrical 6 02-18-2006 06:33 PM
