no brake lights on suburban - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2006, 07:21 AM
frankenstang57's Avatar
waynenewtoneVil
Last journal entry: plans
I've got a buddy who has a '00 Suburban. His lower brake lights don't work, but his 3rd(upper) does. He's replaced the bulbs, switch, fuse, etc. Any suggestions?
Old 09-07-2006, 07:28 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Good chance its the multi-function switch (behind the steering wheel, it holds the turn signal stalk). Try messing with the hazard switch on to of steering column, if that makes the brake lights work, replace the M-F switch.
I have replaced way to many to count for the same problem.
Steve
Old 09-07-2006, 07:40 AM
there is a control module for the lights under the truck in the rear i seen that weather fooks them up. i would pull that out and see if thats it cause if you have the third light on top that means everything from the front of the truck is working like fuse and brake switch hope this helps i can get a wiring diagram if needed
Old 09-07-2006, 07:59 AM
1931 steve's Avatar
Wiki Edits: 4
The third brake light is on its own circuit, yes it is on the brake light circuit but the normal brake lights run through the multi-function switch.
Steve
voltage to tail lights vs brake lights? stratt134 Electrical 12 06-10-2006 07:51 PM
brake lights stay on.... jmtw Electrical 6 03-06-2005 08:48 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
Brake Lights 53chev Electrical 4 12-10-2002 04:49 PM
