I'd still suspect the ground. Try hooking a jumper to the ground to a real good, clean piece of metal. The emergency flashers aren't on, right?
If the bulbs are correct for the socket, and aren't 180 degrees out if an 1157, and there's current, all it can be is insufficient amperage, I would think. That should be a bad ground. The fuses are good? Sometimes there can be a bleed-over of a tiny bit of current that will make a meter register, but w/o any real amperage. |
Did the brake lights work before you replaced the wiring? You may also want to check the switch, located at the pedal. And as cobalt says, make sure the bulb is installed properly.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
Try this--Jump the brake switch wires together, Key on, turn on left or right blinker, if one side blinks OK and the other side has brake light on, you have a faulty turn signal switch, or the wiring in the steering column to the turn switch has been damaged. You mentioned that all the other lights worked including blinkers, just no brake lights--If your blinkers work properly, that tells you that your power, ground and bulbs are good.
If you have 12 volts and it goes away when you plug into it,you most likely have a bad connection somewhere that cant pass enough current to light the bulb. When you are checking for the 12 volts where is the meter ground or test light ground connected. If it is anywhere but the battery negative terminal you are wasting your time. One thing you could try is unplug the harness and find the wire that feeds the brake lights. Run a fused jumper from a known good 12volt source to the wire in the plug and see if the bulb lights. If it does you know both your harness and your ground are ok and the problem is up front somewhere. If the above test passes I would look hard at the brake ligh switc and its connections and the turn signal switch.
You need to eliminate stuff one piece at a time or you will just keep going around in circles. When troubleshooting these types of problems ALWAYS use the battery neg as a ground. This will save you lots of false no power indications.
Artificial Intelligence is no match for Natural Stupidity Chet |
Did you ever resolve this ?
| 95 lumina brake lights | dan65bigdog | Electrical | 2 | 06-22-2008 09:46 AM |
| 58 Chevy Apache : Brake Lights / Wiring Harness | Rathimis | Electrical | 3 | 12-13-2005 08:34 AM |
| 76 firebird with no brake lights | SassyWinds | Electrical | 2 | 01-26-2005 01:22 AM |
| Brake light/turn signal lights wont work together | ChevyForever | Electrical | 1 | 10-04-2004 01:19 PM |
| Ranger Brake Lights | nova69 | Electrical | 2 | 09-01-2004 11:50 PM |
