no brake pressure - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 08-25-2009, 03:21 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Not really, When you remove bleeder-check valve no air is returning back as long the brake is not applied. In-fact gravity will cause the brake fluid to bleed on it's own while changing the bleeder valve. If you do not replace the bleeder check valve, Brake fluid will shoot out every time you hit the brakes.
I may be wrong in this area. Maybe you can leave the check valve in there and just tighten it. If that is case I'll leave it in my car.
  #32 (permalink)
Old 08-29-2009, 01:00 PM
Hey,I received a master from Right Stuff,but of course they sent the wrong one I called Friday and they have no record of sending it.So I will call Monday to see where it is Just for your info,I went ahead and bench bleed the old one,got all the air out of the front,but couldnt get it out of the back resevior.It just keep pumping out air,like there was a leak in side sucking air
HOpe this is the fix.I will let you know when it comes in
  #33 (permalink)
Old 09-14-2009, 05:44 PM
Hey I been real busy at swap meet and buying stuff for car
I finally got a chance to do some work.I bleed brakes today andthought I was getting somewhere,I had pedal pressure,but come to find out its only if I pump the brakes While pumping and holding the pedal I get pressure But after this I hit the brake and it goes to floor,this is the second master from Right Stuff If I pump it twice it locks the brakes,let off and hit it again and it goes to floor I double checked for leaks and got all the air out.I dont really know,I might try and buy another master cylinder,but my options are running out Sorry so late on reply
  #34 (permalink)
Old 09-14-2009, 07:00 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
With the same problem, with 2 different master cylinders, I would suspect something else, as being the problem.
If you are sure you have all of the air out of the system, look to see how much clearance you have between the brake pads, and rotors. The pads should be just touching the rotors, with the brake pedal at rest. You could have gotten some rotors that are too narrow for the calipers, and pads. Resulting in having to press the brake pedal once, to extend the caliper piston, and a second time to apply braking pressure.
This is a very common problem with drum brake applications, when the brake shoes are out of adjustment.
  #35 (permalink)
Old 09-15-2009, 08:01 AM
Frisco's Avatar
Glad To Be Here
If you have replaced the standard brake bleeder valves with "speed" bleeders, you do not have to switch back. After you have bled the system, just fully close the "Speed" bleeder valves and you are done. They have to be "cracked" open about 1/2 turn in order to work.
My experience with them has been marginal. Most brands come with a thread sealant on the threads. The problem is that when they are opened slightly to bleed the brake system, air can and does get back into the system by leaking around the threads. You might wish to try them if you are unable to get a helper when bleeding the brakes, however, I don't recommend them based on my experience.
To the OP (original poster): I answered your I.M. but have posted some additional info here for you to consider. This info is when using GM rear calipers that have the built in parking (emergency) brake. Be sure to read (better yet download) the Parts TechbrakeT1008.pdf file and the residual pressure valves file.
I just re-read your first post.
Since your master and power brake booster is mounted on the firewall, you should not need to have any residual valves in the lines. It will not hurt anything if you do though.
You should still run an adjustable proportioning valve to correctly enable you to balance the brakes from front to rear. The rear brakes should not apply until just after the front brakes do.
The main thing that I see is that you should have the correct pedal ratio IF your car came with power brakes originally. This pedal ratio is important to get the correct amount of pedal travel.
Your primary problem is more than likely the rear caliper adjustment This is of major importance when running the GM rear calipers that have the parking brake as part of the system. It is a internal cam type setup and is not a drum parking brake. It is also a pain to get adjusted. It is explained fairly well in the attached .pdf file below.
Name:	brake bracket.jpg
  #36 (permalink)
Old 09-15-2009, 08:27 AM
Hey thanks for all the help people,I was out early this morning looking over car and noticed I do have a LEAK! Its not pouring out but it is dripping. Its small but it is there,could this be all the problem why it takes 2 pumps to get a pedal? Its har to believe a small leak like that could all this,but I know its pressurized system and a leak could bled it down,and it taes a pump or 2 get the pressure up.Im I on the right track Im going to get on it and get it fixed and see what happens
  #37 (permalink)
Old 09-15-2009, 05:25 PM
Well I fixed the leak and had a pretty good pedal,until I started the car(power brakes) They went to the floor and didnt stop nothing.Put the car in gear and nothing didnt even slow the rotor down I dont know im about at the end,dont really know where to go from here
  #38 (permalink)
Old 09-16-2009, 07:55 AM
lg1969's Avatar
I had the same problem. It turn out the rear drum brakes needed to be tighten up a little more. Some how I still had some air in rear brake line. The front disk were doing fine.
Hope this helps.
  #39 (permalink)
Old 09-18-2009, 06:03 PM
Ok looks like I have it,I called Right Stuff one more time,he said take the calipers loose and tilt them to where the bleeder screw is slightly tilted up.HOld the calipers up with the pads on the rotors and bleed.I believe I did this once,but I kept on going till I got some pressure built up an air out I started the car put it in gear and hit the brakes and the wheel stopped I think I have it Thanks to all who responded Now I can put this car together!
Cold Air vs Ram Air 83SILVRADO Engine 180 05-26-2009 08:59 AM
Chevy Small block, low oil pressure and ticking? Help.. Bowtie_Boy89 Engine 2 02-25-2009 03:52 PM
cross drilled rotors on a 67 chevelle m.docken Suspension - Brakes - Steering 13 02-23-2007 07:26 PM
It's a Mustang II, but what's in it? And a brake problem . . . hduff Suspension - Brakes - Steering 4 11-19-2006 06:00 PM
dash brake light and no pressure? schnitz Suspension - Brakes - Steering 8 11-21-2004 06:52 AM
