it almost sounds like you've been leaking brake fluid somewhere. have you checked the fluid level in your reservoir? i would look at that first and then check your lines to see if there's any noticeable leaks. if there is no leaks and your reservoir is topped up then i would guess that it is your master cylinder.
JB |
HEY PONY: You have internal problems in master cylinder. Fluid is leaking around piston, so that it will not pressurize external circuit. A trip to Auto Zone will cure your problem....GOOD LUCK...DAVE
