Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - No brakes and peddle is solid
Old 04-20-2013, 07:47 AM
S10xGN's Avatar
S10xGN S10xGN is offline
Gotta love a turbo!
Most GM disc brake master cylinders have the front system closest to the firewall. Maybe you blocked the wrong port? Can't tell from your pic, so pop the cap and look at the reservoirs. The larger one is the front brake supply. As stated, remove the prop valve and plumb direct to the fronts...
Russ
