no charge - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2010, 12:28 AM
no charge
i just did a swap from a 4.3 tbi to a 350 in a el camino im using the same alternator but cant remember how it went hooke up i put the plug back but dont see how it would charge the battery
Old 10-05-2010, 11:15 AM
35terraplane's Avatar
no charge
Are you asking how it charges, or saying it wont charge. Looking at the back of your Alt., If it is a one wire. Looking at the plug the right wire connects to the Bat. terminal on the back of the Alt., the big stud coming out. The left wire connects to the Acc. terminal on the ignition switch. Then from the big Bat. terminal on the back of Alt., You use a #10 wire to Bat. terminal of solenoid on starter.
Now if you are using a Ammeter, you would put it in that wire, So you run your #10 wire from Bat. terminal of Alt, to plus side of ammeter, then you run the wire from negative side of ammeter to Bat. terminal of solenoid on starter.
If you have a volt meter you didn't disconnect any of those wires so it should be like it was.
Again I don't know if that did you any good, because I'm not sure of what you are asking. If not ask again, remember, as In anything you have to use the right terms and or explain as close as you can. When are are working with electricity, you have to explain everything whether you think it matters or not.
85 cutlass with 350 wont charge at all why ? josephwaldrop Electrical 2 10-21-2008 05:48 PM
1964 Impala SS - Battery Not Holding Charge 64Joker Electrical 8 07-28-2008 08:14 PM
Just a Dead Battery? 1quiknova Electrical 7 06-07-2006 07:04 PM
Body-shop Owners: How much would you charge ChrisMiddleron Body - Exterior 2 12-29-2004 11:11 PM
no charge! deitwob Electrical 2 06-16-2002 06:46 PM
