no clue whats goin on - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2008, 03:03 PM
Hey whats up guys i have a 1990 chevy half ton with a 350 its been backfiring through the throttle body so i figured it was the heads so i changed the heads on it. That didnt work so i changed the fuel filter and that took care of it for awhile but its started doin it again anyone think you can help me out.
Old 10-29-2008, 03:17 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Welcome to HOTRODDERS.com
Well what kind of back fire up thru the top are you having?
Is it one or multiple?
Did you check the timing chain?
Did you check the firing order?
Checked for bent /sticking valves?
I have seen the pick up coil go bad on those & it will act like a spun timing chain.
What brought you the decision to change out the heads?
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 10-29-2008, 03:24 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Kind of weird to change the heads right of the bat chasing backfire.
Just saying..
Old 10-29-2008, 04:24 PM
lean mixture and/or retard timing. typically.
Old 10-29-2008, 05:08 PM
GMC boogie's Avatar
Check the fuel pressure...you need at least 10psi with 12-13psi being ideal.
Most likely the pump is going south.
Old 11-02-2008, 12:33 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Wow, that is like saying...."I felt vibration in the brake pedal so I swapped out the front axle..." not to rag on you but you blew way past where you need to be on that one.
Old 11-02-2008, 02:18 PM
Rob Keller's Avatar
Wiki Edits: 38
Well he said & I quote No clue whats going on.
& if he replies maybe we can help him out.
R
"SlowRide66"
What are these tail lights for? No clue stereodud General Rodding Tech 9 01-19-2008 07:37 AM
I've had enough, I'm goin fishin Bluepen Hotrodders' Lounge 3 07-12-2007 08:10 PM
wats goin on Toniocaprice Introduce Yourself 1 06-18-2007 12:43 AM
hey every one hows it goin im new R4MM Introduce Yourself 1 04-15-2006 01:53 PM
Fuel coming back up through EGR plate/valve.....car died......whats goin on here? Steve-0321 Engine 2 10-17-2004 07:14 PM
