No clutch shifting - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2006, 07:20 AM
montea's Avatar
tryn to learn
No clutch shifting
is it bad on a transmission to shift without the clutch? obviously without grinding the gears lol
i tried it couple days ago and its surprisingly really easy to do
Old 03-13-2006, 08:32 AM
CrashFarmer2's Avatar
Freezing in arctic Iowa
Last wiki edit: Pre-1980 VIN decoding
Last journal entry: 1978 Chevy pickup battery tray repair
Wiki Edits: 409
Truckers do it all the time.
Old 03-13-2006, 08:36 AM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
Doesnt hurt a thing, as crash said most commercial trucks are shifted without the clutch all day.
Old 03-13-2006, 08:55 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Umm... that's not exactly true! It's can be very hard on the synchronizers. In other words, the trans won't last as long before it starts grinding gears and popping out of gear. You CAN learn to shift without the clutch though. It's a matter of getting up to a certain speed then shifting. When you're at the right speed (rpm) for your trans there will be little or no resistance pulling out of the gear it's in and sliding into the next gear. If there is you haven't hit the right speed yet. It will take a little trial and error to find it.
At the right speed all the trans internals are turning at near the same speed, so no gear clash. The synchronizers apply force to the shaft the gear is getting ready to slide over slightly before the actual change, getting the receiving shaft a chance to match speed before the gear slide. There is a an engine speed where everything in the trans is at the same speed or very close. At that point you can shift without the clutch. Don't be fooled though! If there is some resistance but it shifts anyway, that's the synchronizers doing their job. If you shift like that a lot you'll wear the synchros out -- they aren't designed to work with pressure on them from the engine.
I "speed shift" my motorcycle all the time when at speed, but I've been riding a long time and can tell when it's time to shift by ear. At low speeds you'll have to use the clutch -- that's why it's called "speed shifting" -- you have to be reved up pretty good to hit the equilibrium range for the trans.
Old 03-13-2006, 11:30 AM
montea's Avatar
tryn to learn
so basicly if its done right its fine and if not then expect to be rebuilding the Tranny.
i have done it quite a bit in the last few days and 1 time i got a big clunk like the tranny was coming up through the floor boards and jsut a cuple mild thumps
Old 03-13-2006, 12:01 PM
No-Clutch Shifting
Yup, the big rigs do it all the time, but......
The tranny's are designed for it. Remember, they've got thirteen or more speeds with an engine that has a 500 RPM usable range so the revs don't drop much and aligning the gears at the right RPM is much easier.
Do it on a tranny meant to be de-clutched between gears and, like farna said, you'll be doing a re-build. And not only synchros, you're side loading the bearings on the ttansmission shafts too. Not a good idea IMHO.
Old 03-13-2006, 01:05 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I will be looking for your next question in the Transmission forum.
Old 03-13-2006, 01:39 PM
montea's Avatar
tryn to learn
haha
The reason i wanted to learn to shift without the clutch is my Throw out bearing keeps going. my original clutch had 130,000 miles on it and it worked fine but it never engaged untill the pedal was almost all the way out so i thought it was worn and better replace it so i dont have any future problems. well i did the clutch wich included flywheel machined, pilot bearing, disk, pressure plate, and Throw out bearing, i got about 3,000 Miles before the Throw out bearing went, it would grind when i put the clutch in. so i swaped it out and it was good and i got about 600 miles out of this one and it starting to do it again so i bought a whole new clutch kit again and going to try that, im getting really tired of keep pulling the trans on the car, will be the 3rd time this winter in the Cold. The clutch is hydralic and its auto adjustes so there is no pressure on the clutch. and i know for sure its not putting pressure on the throw out bearing.
This problem with the car has been bugging me so much i want to just go run it into a Tree
Old 03-13-2006, 01:55 PM
Lost in the 60's
Wiki Edits: 4
You might check to be sure that your slave cylinder is coming back all the way. Also you could have air in the clutch system. You have to remove the slave cyl and leave the line hooked up and hold the cylinder with the bleeder in the up most position to bleed properly. Its a two man job.
Old 03-15-2006, 11:22 AM
farna's Avatar
Wiki Edits: 14
It's only auto adjusting to a point. Most slave cylinders have an adjustable end. You have to adjust the clutch initially, and FROM THEN ON it's auto adjusting for wear. The clutch not releasing until the pedal is almost all the way out is correct. Otherwise you have a little pressure on the throw-out bearing which causes it to spin all the time and wear out quickly. It doesn't take much pressure, just enough to make it turn. The throw-out just isn't designed to turn all the time, especially with no pressure on it. I know this doesn't sound right, but with light pressure on it it will wear out faster. It's designed to spin with full pressure on it or not spin at all.
If you don't like the height of the clutch pedal you might be able to adjust the stop. Just make sure the rod on the slave cylinder is adjusted correctly to compensate and the throw-out isn't spinning all the time.
Since you're having so much trouble getting it adjusted you might want to take it to a shop, explain the problem, and see if they will adjust it after you replace. They may not, since you'll be ticked at them if it goes out again, and it could be an installation error on your part. Might be time to bite the bullet and let a shop install a new throw-out bearing. Then if it goes you can blame them for adjustment. Your clutch and pressure plate should still be fine though.
Old 03-15-2006, 11:56 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
No clutch shifting
I agree with farna. Your initial slave cylinder rod setting is probably not correct. Either try resetting it yourself or have a trans shop install the new throwout bearing and if it is still a problem you can blame it on them.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 03-15-2006, 03:58 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
But that has nothing to do with this. Motorcycles use a sequential tranny with dog rings. No syncros and a completely different design
You are right though, its tough on synchros. As long as you don't push hard it should be only moderately more wear. Just gently apply pressure and wait for the speeds to match. Kinda a waste though. A clutch is easy to replace compared to new synchros.
Old 03-16-2006, 08:18 AM
farna's Avatar
Wiki Edits: 14
I didn't realize the MC trans was built that differently, but it does make sense. It's apparently built more like the big rigs -- intended for clutchless or light clutch shifting.
Old 03-16-2006, 06:37 PM
jim..'s Avatar
That 6 Cylinder Guy
The big transmissions have no synchromesh,and have a clutch brake for putting it into gear at a dead stop.
Allthough lots of truckers,myself included,do shift without a clutch,all the major manufacturers of drive trains advise against it,spicer,rockwell,eaton,and others,all say that clutchless shifting puts an undue shockload on the whole drive train and causes premature failure.
Thats what they say,but if your driving for 14 hours a day or so,you cant help but get good at it after a while.
Also,big trucks without synchro must be double clutched if using the clutch,that is you push clutch pedal and pull gear lever into neutral,let clutch back up momentarily so input shaft of trans is engaged to crank and turning the same speed as crank,then push clutch in again and pull into next gear.
Same thing for downshifting,only you rev the engine slightly in the middle of the shift.
Old 03-17-2006, 11:52 PM
86078's Avatar
you lift,you lose!
i've been shifting my work truck w/o the clutch going on 4 years now...in fact the mechanic actully thanked me the other day fofr making his job easier...only truck in the fleet that hasn't had the clutch changed or adjusted in those 4 years...
Borg Warner Shifting problems Spiders Transmission - Rearend 17 12-28-2005 10:38 PM
Clutch problems on 66 Mercury onebadmerc Transmission - Rearend 21 09-23-2005 03:21 PM
Clutch preload? RB401 Transmission - Rearend 0 08-03-2005 09:26 PM
Lakewood Clutch fork clip broke/angle of clutch fork 70bird Transmission - Rearend 3 04-23-2004 07:04 PM
Need Help w/ Clutch Chatter-2002 TA WS6 Josey Wales Transmission - Rearend 2 09-20-2003 07:59 PM
