No compression after cam swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2012, 05:26 PM
Joe428's Avatar
For starters sorry for the long post. I recently swapped my cam in my 383. I set the timing chain on the cam and crank at the stock position (circle to circle). I lined them at 12 and 12 and dropped the distributor in the #1. I cranked the motor and was having some trouble getting it to start. I made several attempts but couldn't get it to turn over, so I gave it a break and tried again the next morning. I tried to start it up several times and it made attempts but still no fire all of a sudden on a certain crank something didn't sound right so I thought I'd recheck my timing. I removed the #1 spark plug to get to TDC but there was no compression on my thumb. I adjust the valves with Frisco's quick adjustment so I feel confident in that sense. It sounds like the starter is the only thing moving ( I want to stress that this occurred out of the blue and did not happen initially or for a while at that.) Idk what happened but now we have no compression. Any help would be greatly appreciated.
Old 04-15-2012, 05:45 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Your terms are a little confusing, at least to me. By crank you mean have the motor rotate with the starter? Then by turn over you mean the same or actually start and run? And saying "on a certain crank" you mean rotation with the starter?
Do you have compression in any cylinders? Did you turn it over and witness the rockers working? Have you looked at the top end to see if your rockers have come loose or you have dropped a valve? Maybe a spring keeper came out? Could a valve have hit a piston and broken? It sounds like now the starter isn't engaging the flywheel or flexplate. Have you had someone look at the starter to see if it's kicking the gear out into the flywheel? I think it's obviously something in the valve train timing chain. What is "Friscos quick adjustment"?
Semper Fi
Old 04-15-2012, 06:41 PM
Joe428's Avatar
[QUOTE=68NovaSS]Your terms are a little confusing, at least to me. By crank you mean have the motor rotate with the starter? Then by turn over you mean the same or actually start and run? And saying "on a certain crank" you mean rotation with the starter?
Yes to all. Sorry for my rambling there
I have not checked the rockers. The motor is rotating with the starter engaging the flywheel. I did not encounter a collision with the top of a piston this motor ran well with the previous cam but it was a bit too much for a daily driver so I went a little milder (to a Lunati 60103 from a Crane 1064)
Old 04-15-2012, 07:08 PM
Joe428's Avatar
Found the problem. Pulled the rocker cover and I had a bunch of loose rocker arms even some with the pushrod out of its seat. I have no idea how they became loose when I followed Frisco's guide and even triple checked the lash and set my set screws( roller tips). Any reasons why my rockers loosened?
Old 04-15-2012, 07:15 PM
Use the intake closing exhaust opening method.
Old 04-15-2012, 08:42 PM
no compression
on sbc shouldnt dot on cam gear be at 6 oclock and dot on crank gear be at 12 oclock?
Old 04-15-2012, 09:00 PM
psbaker75's Avatar
@alkey I was just thinking the same thing. I'm trying to visualize what swapping 12/12 instead of 6/12 would do, swap intake and exhaust events, or relate all timing events to bdc instead of tdc? Either way, I can't imagine getting it to run at all that way.
Old 04-15-2012, 09:43 PM
Joe428's Avatar
That's just to get them lined up correctly. You need to turn the crank one more revolution to get TDC on #1. If not you'll be stuck on #6
Old 04-16-2012, 09:57 AM
1971BB427's Avatar
Absolutely correct! If the timing set is installed at 12 and 12, not 6 and 12, then that's what's causing the valve adjustment issues, and a lot more problems if it's not fixed!
Old 04-17-2012, 12:07 AM
theg's Avatar
Cam timing wrong
Agree . Sounds like this is the problem .
Also if the pushrods were sitting in the lip of the lifters when the adjustment was made could cause the loose rockers problem.
Old 04-17-2012, 05:41 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm thinking he first aligned them at 6 and 12, then rotated the crank one revolution (dots now at 12 and 12) to bring #1 up on compression stroke to set the distributor in.
Old 04-17-2012, 09:59 AM
T-bucket23's Avatar
Wiki Edits: 26
either 6 and 12 or 12 and 12 will work. The only consideration is the distributor install. At 12 and 12 you are on compression on # 1, on 6 and 12 you are on compression on #6.
It is a 2 to 1 ratio so 6 and 12 will become 12 and 12 with one rotation of the crank.
The reasoning for using 6 and 12 is it is much easier to align as the dots are closer together
Chet
Old 04-17-2012, 10:01 AM
T-bucket23's Avatar
Wiki Edits: 26
You did something wrong. Read over the instructions again.
Chet
Old 04-17-2012, 10:07 AM
No it shouldn't. Most instructions show starting with the marks facing each other. That would be the crank gear with the pip mark up at the 12 O'clock position and the cam gear having the pip mark at the 6 O'clock position. The marks are facing each other, therefore, it's easy to see that the tooth alignment is correct (or not). This position times number 6 on firing and number 1 on overlap stating the intake stroke.
Rotating one complete crank rotation returns the crank gear's pip mark to the 12 O' clock position and the cam gear to the 12 O'clock position. This has number 1 at the TDC firing position. There's nothing wrong with initially assembling in this position other than it's more difficult to get a visual between the pip marks that insures they are in alignment. So the typical is to put the timing set on with the pip marks facing each other then rotate the crank 360 degrees or one complete revolution which is 1/2 a revolution of the cam gear resulting in the pip marks of both gears facing in the 12 O'clock position and number 1 at TDC firing. The opposite position of crank at 12 and cam at 6 has number 1 at TDC on overlap ready to start the intake cycle where the exhaust is closing and the intake opening. This would be the model for any other cylinder that is one crank revolution from TDC on the firing stroke.
Why Chevy chose this positioning makes no more sense to me than the old Ford Y Block having 12 timing chain pins between the pip marks when they are horizontal to the engine or timing the old International from cylinder #3 instead of #1. The need to be different boggles my simple mind, I like the KISS method.
Bogie
Vortec Head Swap....Too much compression?? zildjian4life218 Engine 14 01-04-2010 04:40 PM
compression and cam help schottout Engine 1 09-20-2009 04:16 PM
Cam Swap, No Compression, Help?! Houman SS '70 Engine 6 05-16-2005 04:42 AM
cam/compression? SBC4ME Engine 5 01-26-2005 09:23 PM
cam/compression? SBC4ME Engine 1 01-24-2005 09:35 PM
