No dash lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2004, 12:27 PM
Thumbs down No dash lights
Hi , I'm new to this site , and have a couple questions for you all . I own a 86 s-10 350 , currently under construction . I went threw most of the bullintin board to try and find a answer , but i didnt find anythin so i thought i would just post . But my question is how come my dash lights suddenly stopped workin . I have been workin on the interior a lil and painted some dash pieces , While i was doin that i pulled the gauge cluster out and check all the blubs and they all seemed to be good , from what i could see . i think im gonna end up changing them anyways , but any suggestion why my dash lights dont work anymore ?
Now for my other question . i tore out my headliner cause it was falling down . It's all in pretty good condition cept that it was fallin down . so i thought i would customize it a lil add some flames to it , but my question is what do i use to reattach the material back to the mold ?? i noticed its a real thin material and didnt wanna use something that might soak threw . Maybe some 3M adhesive ? your help would be great .
thanks , Jake
Old 02-17-2004, 02:03 PM
Custom User Text:
http://www.all-nu.com/html/customflames.htm
Old 02-17-2004, 02:47 PM
Check and see if you have any tail lights and check your fuses. On many vehicles, if you blow the fuse for your tail lights, your dash lights don't work either. If this is the case, there is probably some reason why your tail light fuse is blowing. I had that problem in my 63 when a tail light wire wore through and shorted out.
Old 02-17-2004, 03:55 PM
Custom User Text:
Make sure you did not turn the Headlight / Domelight switch to far the wrong way.
