No electrical power in 79 T/A - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2009, 07:26 PM
MOTOR HEAD's Avatar
Born to Wrench
Hey guys , I got my T/A running again about a week ago & have been moving towards pulling it out to wash it up until 2 days ago , I have had some sort of electrical failure somewhere! I had just had it running and was in the process of adjusting the fuel air mixture because of a slightly rich smell , I then decided to recheck the timing. I was bumping the starter to bring the timing mark around so I could mark it with some chalk and that's when everything quit working. Now when the key is turned my guages don't respond , the pump doesn't run & the starter is getting nothing also. I replaced the starter & solenoid hoping it had gone bad but it wasn't the problem. The battery is fairly new , the alternator is new , I checked all the wiring going to the starter , it has a new ground cable , a new negative battery cable , the old positive cable seemed to be ok. The only thing that works now is the clock on the tach & when I turn the key it stops. I also pulled the coil cover on the distributor and the coil & leads look fine , my lights don't come on or brake lights when the pedal is pushed. I don't know why it did this or what is causing it. Hopefully someone can help so I can finish up and move on to another project!! Thanks in advance..
Old 09-20-2009, 10:30 AM
The first problem I would look for would be a blown fuse link feeding the circuit to the inside of the car. These are usually located at the starter-Pos batt. connection. They will be 10/12ga. red wires. One will feed back up to the alt. and the other one will usually go the junction block on the firewall, then thru the bulkhead connector to the fuse block and key switch.
Old 09-21-2009, 07:54 AM
MOTOR HEAD's Avatar
Born to Wrench
Thanks Gizmo , I got it going yesterday. I think it was something to do with the solenoid. I dropped the column and messed with the ignition switch to see if it was doing it's job first. Then I went across the shop to look @ the factory wiring on my wifes 79 T/A to make certain everything was correct or see if anything important was out of place. I wound up hooking the charger directly to the cables without the battery on a low 10-amp charge cycle and pulled the light switch & they came on. So I figured it had to be a stuck solenoid or something , I tapped the key and engaged the solenoid a couple times then hooked the battery back up and the pump and all power came back , starts fine now and has plenty of voltage. Thanks for taking the time to send some information , I appreciate the effort.
Blower Carb Boost Referenced power valves steve392 Engine 18 01-23-2012 12:06 PM
Respectable paint on 120V compressor? Slickriffs Body - Exterior 43 06-10-2010 02:01 AM
Using car stuff to power your house? 58Apache Hotrodders' Lounge 12 09-21-2008 10:45 PM
79 El Camino with Type II Power Steering dlc1979 Suspension - Brakes - Steering 3 06-29-2008 07:19 PM
79 straight 6 how much power ??? CamaroHunter78 Engine 13 12-10-2007 12:59 AM
