no fire
i was driving my truck down the road today and it just dies on me like i turned off the key so i pull into pizza hut parking lot change the coyle,module,cap,rotor,button and i checked to see if i was getting fire through the plug wires by sticking a screwdriver in them and holding it against the block and still no fire and then i checked the hot wire from the ignition to the dist and it is getting electricity so any ideals or questions?
its a 1984 chevy blazer with a 350 all plugs no fire
got a update i tested the voltage for my wire that goes to the distributor and it reads 11.83 does it need to be excactly 12 volts or higher to reach the rotar ect? |
Might sound dumb but make sure the 3 prongs for the module plug to cap are all straight and plugged in also make sure you have the wire hooked to batt side of cap and not tach. 11.83 is plenty to make it fire. Where all parts new you put on?
uhh thanks for the help but i found a higher voltage wire and ran that to the distributor and it started right up so i gues 11.85 volts isnt enough (thats not while the motor is cranking over)
me to thanks for ur help
Review
hello Everyone !
PLR Article Packs |
| A different kind of Hot Rod | Lonestar | Hotrodders' Lounge | 59 | 08-19-2008 10:28 PM |
| My Brother's house cought fire | Malibucdl | Off-Topic | 3 | 02-19-2006 11:11 AM |
| Kerry will continue the war! | lluciano77 | Hotrodders' Lounge | 60 | 08-04-2004 06:39 AM |
| Fire extinguishers | Bluepen | Garage - Tools | 11 | 03-26-2004 04:48 PM |
| Mallory Hi Fire Box problems | black66 | Electrical | 2 | 08-03-2003 11:55 PM |
