no fire - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2006, 07:14 PM
no fire
Guys I Recently Was Given A 1993 Ford Explorer But I Cant Get Fire To The Plugs. I Have Replaced The Coil Pack,ignition Control Mod,the Crank Sensor And Even Put A New Computer In This Thing,and Still No Fire To The Plugs...please Help Before I Crush This Piece Of ----.
Old 03-04-2006, 07:16 PM
poncho62's Avatar
Wiki Edits: 5
welcome Bobby...this post belongs in the engine forum. I am moving it there.
Old 03-04-2006, 08:48 PM
65Stanger's Avatar
Check the water, check the oil
Check all of your wiring to everywhere. Make sure that everything's hot with a voltmeter.
Old 03-05-2006, 12:04 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Sounds like it could be one of to possible Failures, the TFI module, or the Hall Effect Vane Switch (Magnetic Pickup) .
The module you should be able to pull and have tested at your local auto zombie..
The Hall effect device requires pulling the dizzy, and disassembling the center shaft to replace the unit. Those Dizzy's are totally rebuild able, so you need not buy a new one unless the metal parts are actually past runout.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 03-06-2006, 08:26 AM
trieme's Avatar
PURE AMERICAN MUSCLE
we had that problem in my truck a while back. The contact point on the distributor had fallen off.
Old 03-06-2006, 09:15 AM
TechnTool's Avatar
OldSchool MotorHead
If all the hardware is good, then check the wiring harness that runs under the accumulator. It has all the vital wiring for the ignition system, PCM, and TCM. It is a common point for chaffing and general trouble.
Old 03-06-2006, 09:43 AM
This may sound trivial but I actually had a car NOT start once to due a crappy rotor, certainly worth replacing
A different kind of Hot Rod Lonestar Hotrodders' Lounge 59 08-19-2008 11:28 PM
My Brother's house cought fire Malibucdl Off-Topic 3 02-19-2006 12:11 PM
Sequential fire vs. Batch fire Injection Siggy_Freud Engine 7 09-08-2004 11:15 AM
Kerry will continue the war! lluciano77 Hotrodders' Lounge 60 08-04-2004 07:39 AM
Fire extinguishers Bluepen Garage - Tools 11 03-26-2004 05:48 PM
