No Fire, HEn I Install - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2012, 09:40 PM
MrPhotographer06's Avatar
Army Strong
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
So, long story short, I had a re-man 5 pin HEI dizzy that i put the 4 pin module in and after hooking it up in the truck, it had ZERO fire. I had the hot wire going into the dizzy straight from the battery, and it wouldnt fire a lick.
So, I pulled that one out, thinking my module upgrade failed, and with my other stock HEI dizzy and yet again, NO fire. But, thinking back to it now, i checked the wire for continuity and it said 10ish volts.. By it not having exaclty 12 volts would it cause it not to charge?
whats the best remedy?
Thanks,
-Cam
Old 04-28-2012, 10:11 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
By checking for continuity, do you mean resistance and sure the reading wasn't OHMs? Or did you check voltage after the continuity test and get the 10 volts??
Semper Fi
Old 04-29-2012, 07:17 AM
Army Strong
I said that wrong. I checked voltage at the dizzy and had like 10.4 volts, the same I had at The battery obviously because I straight wired it.
Old 04-29-2012, 07:46 AM
T-bucket23's Avatar
Wiki Edits: 26
Why is the battery voltage so low. I am sure that is not helping you.Did the engine run with the 5 pin module. How exactly did you "convert" it.
Chet
Old 04-29-2012, 08:23 AM
Army Strong
I took the 5 pin module out and put in a 4 pin. the 5 pin has an adapter that allows the pickup to be plugged up and piggybacked with the outside connectors.
so the 4 pin only requires the two pickup wires. i changed the module.
but to eliminate that, i took the "converted" dizzy out and put in a different one i had that worked...
no fire Wildwestshow Electrical 7 12-05-2010 02:20 PM
FIRE!!! help Camaro1980 Engine 3 05-23-2007 03:44 PM
Sequential fire vs. Batch fire Injection Siggy_Freud Engine 7 09-08-2004 10:15 AM
Fire!!! johnsongrass1 Garage - Tools 6 02-16-2004 07:19 AM
My YJ wants fire. 94_Yj Engine 1 11-25-2002 12:01 AM
