No fire to plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2004, 03:02 PM
Novaman78's Avatar
Kill It & Grill It
Last journal entry: New door panels
No fire to plugs
I have a 1986 sbc 305. I did a basic rebuild but added a cam and headers intake and carb. Anyway i have had the car running for about 1 month now i only have about 100 miles on the engine. today i was on the highway headed to school and the car just dies. I try starting it and t wont start i would not even hit. I towed it home and after school i started trying to fix it see whats wrong. I figured out its not getting any fire to the plugs. The distributor is rebuilt the cap, rotor, and coil have a bout 100 miles on them then today i got a new module and ignition pick up coil. Still nothing. I tried a coil out of a engine that ran so that i new it worked but i still don't have any fire. could someone tell me what is going on? Yes i checked and there is power going to the distributor. I don't know what year the dist. is but it is a big HEI not the small one. I have tried every thing i know some one please help all suggestions welcome.
Old 09-01-2004, 03:20 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Did you check the mag pick up?
Old 09-01-2004, 03:23 PM
Novaman78's Avatar
Kill It & Grill It
what is the mag pick up? Im still fairly new to engine building. I am still learning
Old 09-01-2004, 03:25 PM
New Member
So fire is getting to the distributor, but not going thru the distributor, is that correct?
Have you tryed jumping the distributor directly from the battery?
Old 09-01-2004, 03:37 PM
Novaman78's Avatar
Kill It & Grill It
Correct fire to distributor but not after.
No i have not tried that i will go out and try, let you know what happens.
Ok still nothing even after running direct wire from battery to dist.
Old 09-01-2004, 03:40 PM
docvette's Avatar
Wiki Edits: 12
Fuses
Doc here
Is the Car TBI or EFI? Check the Computer fuse.
Does it have a crank positioner? look there.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-01-2004, 04:35 PM
Novaman78's Avatar
Kill It & Grill It
Thanks every one but i figured it out. It was the coil. I tried 2 and just for the heck of it i tried a 3rd one and soon as i hit the key it started. I fell lots better now.
