No floor pan. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2011, 05:30 AM
No floor pan.
33 chevy 3 wdw coupe, came with s-10 floor. After I remove it, the body will be flimsy, how do I get the right dimensions of the width in order to weld temp braces? really dont know where to begin.
Old 04-08-2011, 08:13 AM
Wiki Edits: 27
desert tin rebuild.
I picked up some rusty body parts in the nevada desert. Make unknown. I put a sheet of pylwood on a large pallet then up on a roll around table. I drew a grid pattern then lined up the cowl , quarter panels etc on the grid, used drywall screws to hold them. then started bending sq and Rect steel to build a sub structure. Old chevies usually have most of the wood sub structure gone or useless. Someone might have a good car you can measure. otherwise move the panels till they look and fit right.
Old 04-08-2011, 09:51 AM
35WINDOW's Avatar
Last journal entry: Dash Mock-up
Do you have the Frame you will be putting it on?
what to put on floor chrispare Body - Exterior 2 01-25-2010 09:58 PM
floor pan help MrPhotographer06 Hotrodding Basics 6 01-24-2007 01:16 PM
cab floor 78 chevy truck Body - Exterior 5 02-16-2004 08:16 PM
Floor Pan? Mike_82 Body - Exterior 2 02-10-2004 02:55 PM
cab floor 78 chevy truck Hotrodding Basics 3 10-29-2003 01:40 PM
