No forward gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2003, 04:42 PM
unseenthings's Avatar
No forward gears
I have a '74 Cadillac hearse, which has the Turbo 400 from what I understand. One day I went out, started it up and put it in drive, and it went forward a little, tightened up, then just did nothing. Now all my forward gears act like neutral and do nothing. Fluid level is good, and reverse works.
Will a rebuild fix this?
Thanks
Old 09-11-2003, 05:12 PM
I fight what you f33r!
man, that doesn't sound healthy, I'd like to know the answer also
Old 09-11-2003, 09:34 PM
foward clutch is wasted, or third clutch is welded together, when in drive gear, does the engine rev up or does it act like it's in gear and not move good luck c-ya sling
Old 09-12-2003, 09:28 PM
ya I agree probably the forward clutch is done.
