Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - no forward gears 727
Old 06-21-2009, 05:36 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
since the trans backs up per yur post...
that tells me the pump is working enough to move the car.
the converter is transfering power to the trans via the input shaft.
direct clutch is operating since the car backs up
No forward gears in any shifter position? = 1 , 2 , 3 ?
That makes me think there is a problem in the forward clutch pack or the roller clutch in the back of the case
