-   -   no forward gears...help please (http://www.hotrodders.com/forum/no-forward-gears-help-please-18699.html)
Rubberman2003 06-28-2003 05:28 PM
I have a TH350 in my camaro. When i put the shifter to Reverse she moves just fine, then all below that dont work, when i put it into the 1/2/3 slots it just revs, it acts like it wants to move just for a second in the lowest slot (1) but it doesnt. I checked the fluid its fine. the linkage is ok to, or reverse would be in a wrong spot. any ideas?
airworld2 06-28-2003 07:53 PM
trans
forward plates are burnt up ...... trans rebuild time........
Rubberman2003 06-28-2003 08:56 PM
how much will that cost if thats what it is? Tranny was bought through advanced autoparts..rebuilt (i know i know)
Hollywooding 06-29-2003 12:55 AM
taking it from a mech. who specializes in auto trans. When looking to rebuild any trans, it's best not to be specific when quoting "how much is this gonna cost me". Most of the time you never now until you pull it apart. That's just the way it works. sorry.
(ps always drop a new tq cvrtr its always good practice and less hassle down the road)
adtkart 06-29-2003 05:43 AM
If you are not going to do it yourself, your best bet is to go to a trans shop and work out a deal to swap your rebuilt for one of theirs, including the convertor. You don't know how many bad parts were put back into that one.
airworld2 06-29-2003 09:40 AM
trans trouble
good rebuilds on this unit starts 600 and only goes up depends on what you want inside.
Rubberman2003 06-29-2003 10:32 AM
im going to pop off the pan and look, i THINK/HOPE a checkball is just outta place, there is only 1 in there now with my shift kit. If this is the case do i still need a convertor? or just put the ball back and go?
Silver_Camaro 06-29-2003 11:34 AM
I'm with airworld on this one. Plates a probably burnt up. If this is the case then you can get a trans rebuild kit from a local parts store (Autozone) for around 150 to 200. It comes with the plates and all. But if you don't want to do it yourself then I'd suggest possibly finding some one local that does rebuilds in their garage. These guys can be bartered down to nearly nuthin and will usually do a great job because they want to make a good name for themselves and get more bussiness. My 82 camaro has a 305 with the stock TH-200 tranny. When it went out I had a guy locally do it. He completely rebuilt it, acid dipped it to clean it up, installed a shift kit in and gave me a 3 month warranty on it all for only $300. After that all I had to do was buy a new torque converter and put it back in my car. Haven't had a single problem with it yet and its been a year now.
Good luck,
Panther
adtkart 06-29-2003 01:11 PM
I would be surprised if the only thing inside that is needed comes in the kit. Knowing the history on "rebuilt" parts that Advance sells, I would bet on more parts than that being worn out. Although I have never seen a trans that they sold, I have seen the water pumps that make noise or leak, alternators that don't charge, and starters that won't work(what is usually wrong with them to require replacement in the first place). If you take them back, they will give you another just like it, and put yours back on the shelf. I have seen it done before.
