Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - No fuel to carb?
Old 11-26-2005, 12:32 PM
1982 SS's Avatar
1982 SS 1982 SS is offline
Flamethrower
Last journal entry: More Cooling fan pictures.
Just a thought, if you could get an electric fuel pump (borrow one or get a really cheap one) and attach it to the inlet line at the mechanical pump and prove you can draw fuel through the lines. If that works, then I think the mechanical pump would be bad or the line between the pump and carb is blocked or pinched. you could also use a bucket for a tank and put a line from the bucket to the inlet and then it goes to the carb from the pump. That would also prove the same thing.
