No fuel to carb, do have fuel at pump inlet - replace? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2010, 02:46 PM
I'm messing around with a Chevy 350. My son and I previously replaced the fuel tank (it was very old - cheaper to replace than to clean), replaced the fuel sending unit, replaced rubber fuel lines. We had it running for a while, but...
Now we're not getting fuel to the carb. I checked the fuel line leading to the carb and it is dry. I decided to replace the fuel pump, but when I started to disconnect the fuel line leading to the pump, there was plenty of fuel in it.
So - replace the pump anyway? Why would I have fuel at the fuel pump inlet, but none at the outlet? Just trying to figure it out. (I've got a replacement fuel pump on hand - just wanted to figure out if something else might be the problem)
Old 04-17-2010, 02:54 PM
DoubleVision's Avatar
Replace the pump and check the oil. If you smell gas in the oil change it right away. Sometimes the fuel pump can rupture internally and leak fuel into the engine. Make sure you pack the spring cavity of the replacement fuel pump with lube. Not doing so will make the spring in the pump overheat and fail. I wouldn`t use heavy grease, use a light lube like break in lube or moly lube.
If you get it together and still can`t get any fuel to the carb then I`d say the sock in the fuel tank has collapsed.
Old 04-17-2010, 08:31 PM
Old pump is off. New pump is in hand. The fuelpump pushrod is behind the plate. Do I need to remove the plate to get at the fuel pump pushrod? How do I get the thing pulled up and on the lever?
Sorry for asking goofy questions. Never replaced a fuel pump on a 350 before.
Old 04-17-2010, 08:38 PM
I think I found an answer using trusty google. Remove plate. Use a bolt (or something) to hold up pushrod. Bolt plate back in place, then go about my business. Sorry for posting a dumb question.
Old 04-17-2010, 08:52 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Info from the Crankshaft Coalition Wiki:
http://www.crankshaftcoalition.com/w...P,_REPLACE_SBC
Old 04-21-2010, 09:18 PM
Thanks. That was a great how-to. I really appreciate it. Fuel pump is replaced. I think I got the pushrod in right - no strange noises, anyway. It was really tight working on it, not much room (the car is an older kit car, looks like an Austin Healey - that 350 takes up a good bit of space in there!).
Charging the battery up, and hoping to see some fuel. I let it crank for a little bit, and didn't see any gas - so I'm hoping I just need to crank a bit to prime the pump.
Anyway - battery goes back in the car tomorrow, and I hope to get fuel to the carb. Fingers crossed.
Old 04-22-2010, 05:18 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Judicious use of starting fluid will lessen the amount of cranking required to get fuel up to the pump and carb. Just follow the directions on the can.
Old 04-22-2010, 08:10 PM
New Member
changing fuel pump
chevy fuel pump need to take steps to release the fuel pressure before you can remove the fuel pump.Make sure that theirs no fuel pressure on your fuel lines or fuel pump then you can proceed in changing the fuel pump.If your fuel pump mounts underneath the car, it will be held in by a couple of bolts. You can locate your fuel pump by sliding underneath the car and looking just in front of the gas tank on one side of the car or the other.
Last edited by engineczar; 06-15-2010 at 06:04 AM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 04-22-2010, 08:41 PM
fuel pump
just in case you missed the rod old school way, pack the push rod with bearing grease then put it in place helps hold the rod, or a feeler guage works good also, normally only big blocks have the hole you can put a bolt in i believe hope this isnt to late
Ford 1 and 2 piece fuel pump eccentrics lluciano77 Engine 34 06-12-2014 04:27 PM
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
New Carb or Fuel Pump zildjian4life218 Engine 11 11-21-2009 12:47 PM
93 Suburban fuel pump sabino56 Engine 8 09-10-2005 02:54 PM
vapor lock, sbc, hot fuel pump Walker Engine 1 07-19-2004 10:31 PM
