no fuel inside carb when i crack the throttle open - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2002, 06:09 PM
Question no fuel inside carb when i crack the throttle open
there is no sight of gas inside the carb. my electric fuel pumps cuts on and my pressure guage is steady around 7. my sight screws off i can see fuel just at the line. what can i do to fix. this carb has about 20miles on it. holley 750 with manual secondaries... <img src="confused.gif" border="0">
Old 09-17-2002, 06:55 PM
E.T. divided by $ spent= Speed
Post
Not sure what you mean????When you pump th gas the shooters don't squirt????If thats it its in the excelerator pump either bad diafram or dirt in the carb somewere.
Old 09-18-2002, 04:57 AM
Post
thanks for the reply... exactly no gas from the squirters. okay i will check for crud around them.
