no gear change - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2008, 11:30 PM
no gear change
hi i'm dave
i have a 1981 chevy van with a thm 350 gearbox and it is stuck in first gear.i have changed fluid and filter and given the pan a good clean, could see nothing obvious wit the cover off,but i don't know much about auto boxes,can anyone help?
Old 06-03-2008, 02:57 AM
SSedan64's Avatar
Originally Posted by d.binding
hi i'm dave
Do you mean it will not come out of 1st gear? Shifts into 1st but does not shift into 2nd, 3rd or reverse? Does it have TH350 or TH350C with lockup torque convertor?
Old 06-03-2008, 04:40 AM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
Does it have park and neutral or not?
I am not transmission expert, but I have seen some weird things with them. Linkage slipped, linkage bent, something slipped inside the pan where the linkage hooks up, on an older 350 I once saw the little "S" hook fall out in the pan and it would shift to whatever gear it wanted to going down the highway (even reverse!).
I even saw one once where a valve body bolt was working itself loose. Every time it would come out a little further, they would lose a gear. first park went, then reverse, then neutral, and then it started on the forward gears. It just happen to be above the linkage and was blocking it.
Has this transmission or the steering column been worked on recently? Something could have been hooked up incorrectly.
Old 06-03-2008, 07:39 AM
350 gear problem
thanks for your reply.it will go into reverse ok and back into first ok, at one point it would shift i f i shifted from 1st to 2nd then third manualy but now it stays in 1st whether i shift manualy or not,the shift linkage or steering colomn has not been dismantled
Gear Drive to Timing Cover Clearance Double_v23 Engine 5 01-11-2008 11:08 AM
Gear Drive to Timing Cover Clearance Double_v23 Engine 7 01-10-2008 07:12 AM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
Gear Swap. M&M CUSTOM Transmission - Rearend 3 06-26-2004 05:53 AM
Gear Ratio change 78Corvette Transmission - Rearend 5 04-11-2003 07:01 PM
