Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - no gear change
Thread: no gear change
Old 06-04-2008, 03:33 PM
C-10's Avatar
C-10 C-10 is offline
Revolution Calling
Last journal entry: Poverty caps live on.
Check out the modulator too. Draw a vacuum on it and make sure it doesn't leak off.
Also, check the plastic governor gear. It could be stripped. This is located on the driver rear of the trans. Remove the round cover and pull the gov out.
Check the valve for sticking while you have it out.
