| View Poll Results: High volume oil pump...???? | |||
| its good for normal daily drivers !!! |
7 | 26.92% |
| Its good for High performance race cars only !!! |
7 | 26.92% |
| Its good for trucking,towing !!! |
6 | 23.08% |
| Please avoid HV Oil pums !!! Get the regular one !!! |
6 | 23.08% |
| Voters: 26. You may not vote on this poll | |||
LinkBack | Thread Tools |
You need to measure the diameter of the crankshaft journal, and then measure the diameter of the main bore with the bearings in it (or measure the main bore and bearings separately). Same thing with the rod journals. You can also use plastigage to get a rough idea of the clearance if you can't measure it. You want to know how much space there is between the crankshaft and the bearing, should be about 0.002".
| high oil pressure HELP PLEASE! | RDavis81 | Engine | 8 | 03-25-2009 06:44 PM |
| oil change- step by step instructions for women and men | Fireball | Hotrodders' Lounge | 38 | 08-30-2008 07:39 AM |
| High Volume Oil Pump | 1948Butch | Engine | 8 | 02-10-2005 01:25 AM |
| Chevy oil pumps | Knobie | Engine | 1 | 01-16-2003 03:52 PM |
| High Volume Oil Pump (Good or Bad) ? | white66coupe | Engine | 5 | 11-05-2002 03:27 PM |
