Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is it no good to have a High volume oil pump?
Old 01-25-2008, 10:40 AM
CNC BLOCKS NE CNC BLOCKS NE is offline
CNC Blocks Northeast
i bought one,high volume,is it no good ?
some people say that the pan can get dry and cause the lack of lube.-
In fact they sell oil flow to the top restrictors
http://cgi.ebay.com/New-Chevy-V8-Ren...QQcmdZViewItem
Is it good to have a HV Oil pump ?
It all depends on your bearing clearances rod, main and cam and from there lifter bore clearance. 99% of the street performance engines we build e use standard volume high pressure pumps.
On all our engines build we line hone all our blocks and hone the big end of the rods and try to maintain .002 to .0025 on the rods and mains for street performance and if the cam housing bores are over size we line bore them to the correct size.
