Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is it no good to have a High volume oil pump?
Old 01-25-2008, 02:45 PM
Rick WI Rick WI is offline
What you will see with the high volume pump is higher pressure at idle and low load conditions. Assuming you use a standard pressure spring it will bypass the extra volume at the the rated pressure just like a standard volume pump would. Basically no drawback then with a high volume pump and standard pressure spring.
There should be two springs included with your pump, assuming you order the same ones we do.
